400 engine stuff
Old Dec 18, 2012 | 06:28 PM
1978-Punisher's Avatar
1978-Punisher
400 engine stuff
OK so this my first post been here a lot but not as a member. I have 1978 F250 w/400 well I am getting a new 400 installed next week with a double roller timing chain and a Cleveland cam. My question is what would you recommend doing wise before it goes in. Keep in mind this is my dd.
Old Dec 18, 2012 | 07:42 PM
rancheronut's Avatar
rancheronut
wellcome from other person that call greatfalls home!
Old Dec 18, 2012 | 09:16 PM
1978-Punisher
Thanks there is another guy on here somewhere he is also Air force he has a white dent with grey tree painted all over it.
Old Dec 18, 2012 | 09:48 PM
vic_v8's Avatar
vic_v8
I'm guessing the timing will be straight up? and if you can afford a little port work, that's always good. same with an aftermarket intake.
Old Dec 19, 2012 | 11:30 PM
johnson2007's Avatar
johnson2007
I'm guessing you got the engine from automotive machine? I'm basing that off of the Cleveland cam description... That's what they told me too, but couldn't give me any specs or anything on the cam.
Old Dec 20, 2012 | 12:01 AM
85e150's Avatar
85e150
Almost any cam is better than stock.
Are they putting any compression in it? There are pistons available so you don't have to settle for 7ish compression.
stroken7.3
Jan 31, 2018 05:10 PM
Derf47
17
Sep 18, 2016 11:01 AM
mojo645
Dec 30, 2009 01:51 PM
justforkicks
Mar 25, 2009 09:33 AM
Phillip Guidry
Jan 4, 2000 09:16 PM
