Wake up a 400?
Old Dec 28, 2009 | 07:19 PM
mojo645's Avatar
mojo645
Wake up a 400?
I have a 78 4x4 150 supercab with a 400 and its just a dog. Its geared pretty high and this thing has trouble pulling itself out of a wet paperbag. Not interested in any gearing changes. Cruises nicely once you're up to speed! I had one guy say that a new timing chain set with a 4 degree offset does wonders for the 400. Just wondering if anyone else has had any experience with that or have any suggestions. Not an everyday driver.
Old Dec 28, 2009 | 07:28 PM
79FordBlake's Avatar
79FordBlake
Aftermarket timing set helps. An aftermarket towing/rv cam helps alot to. Also helps to get some different pistons and bring compression up.
Old Dec 28, 2009 | 09:34 PM
fordtech08's Avatar
fordtech08
an intake and 4bbl makes a huge difference
Old Dec 28, 2009 | 09:44 PM
monsterbaby's Avatar
monsterbaby
Lets get this down in the engine forum.
Old Dec 30, 2009 | 12:27 AM
mustang81's Avatar
mustang81
Headers will help to with cam, intake manifold, 4 barl carb and timing set straight-up, but you haven't done anything yet to boost the compression like 79FordBlake said. With all this change will make a HUGE difference, you will probably think your in the wrong truck.
Old Dec 30, 2009 | 05:54 AM
SoCalExile's Avatar
SoCalExile
The February issue of Classic Trucks has an article about just this. They took a '76 400, cleaned it up, bored it over .030, installed Cleveland pistons, stock cam, and compared a 2v intake and carb to a 4v intake and Holley 750 4 barrel. They got some pretty decent numbers on the 4v setup, 301hp @ 4100 with 429 lb-ft of torque.
Old Dec 30, 2009 | 08:33 AM
fordtech08's Avatar
fordtech08
yeah I can't wait for the next issue if you look at the first picture it has aluminum heads I want to see what that does
Old Dec 30, 2009 | 01:51 PM
SoCalExile's Avatar
SoCalExile
If anyone hasn't read the article here it is:
Ford 400M Engine Rebuild - Classic Trucks Magazine
youngone1234
Sep 3, 2016 04:48 AM
Brandon_H
Oregon Chapter
33
Oct 20, 2013 12:26 PM
WHRAVEN
Jul 23, 2013 07:34 PM
650
May 7, 2012 10:16 PM
weverette1
Feb 14, 2005 08:39 PM
