coolant leak
Old Dec 18, 2012 | 04:45 PM
4CFarms's Avatar
4CFarms
coolant leak
I am having a problem with a very sporadic leak. Some nights ill come out and theres a big puddle of antifreeze on the ground and sometimes not... I got a antifreeze pressurizer to check for leaks and i feel dumb but im scratchin my head on how to put the damn thing on cus we dont have a normal radiator cap. All i see is the two gromets on both sides. Do i take those out or how do i go about this. Any and all help welcome!!!
Old Dec 18, 2012 | 04:56 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Well theres really only so many places it can be leaking, as long as you dont assume the worst (cracked block, head, etc). Where under the truck is it puddling? Some of the usual places include from the oil cooler and if the hoses are old. There are also some UV dyes, similar to the ones for AC leaks, that you can add to the coolant and use a UV light to find it.
Old Dec 18, 2012 | 05:33 PM
madpogue's Avatar
madpogue
You put the tester on in place of the reservoir cap, if it has an appropriate fitting for it.
Old Dec 18, 2012 | 06:42 PM
Red97350's Avatar
Red97350
The oil coolers seem to start leaking when it gets cold out. Where is the puddle under the truck?
Red
Old Dec 18, 2012 | 06:56 PM
4CFarms's Avatar
4CFarms
The puddle is towards the front practically under the bumper.
Old Dec 18, 2012 | 07:10 PM
Ford4Life7.3
Well, that leads me to believe its coming from the radiator or hoses. Crawl under there and check them.
Old Dec 22, 2012 | 04:43 PM
4CFarms's Avatar
4CFarms
If it was from the radiator, wouldn't it always be a constant leak though?
Old Dec 23, 2012 | 01:06 AM
Ford4Life7.3
I cant tell you anything other than where to look. Only way to find it is to get under there and look. Sounds like its either your oil cooler, a radiator hose, or the radiator.
Old Dec 23, 2012 | 03:05 AM
mkeith54's Avatar
mkeith54
When my water pump started going out I would get a leak toward the front of the truck on occasion. Turned out the bearings were bad.
Old Dec 24, 2012 | 02:42 PM
4CFarms's Avatar
4CFarms
I replaced the water pump this summer. I'm gonna check all the hoses but where is the oil cooler located?
Old Dec 24, 2012 | 04:36 PM
Red97350's Avatar
Red97350
Driver's side, back end is right above the oil filter, front end bolts into the front cover.
Red
ryan09
2009 - 2014 F150
13
Sep 4, 2017 12:24 PM
copen93
Nov 30, 2014 11:56 PM
eigenvector
1983 - 2012 Ranger & B-Series
Mar 8, 2011 08:11 PM
michaelbrainardatwor
Mar 16, 2010 01:40 PM
joe blow
Mar 6, 2007 11:25 AM
