explorer starts then stops immediately
Old May 25, 2003 | 01:12 PM
gla1967's Avatar
gla1967
Angry explorer starts then stops immediately
When I start my explorer it starts then shuts down immediately. If I keep my foot on the gas I can start it and drive. as soon as I release my foot it dies. Just trying to see if any one has an idea before I bring it to a mechanic.
Old May 25, 2003 | 11:45 PM
Ford_Six's Avatar
Ford_Six
Welcome to FTE!
What year is yours? I worked on one before, a 91, that had a stalling problem. Turned out somebody had messed with the idle stop adjustment on the throttle body. I would also suspect a plugged or inoperative idle air control solenoid. Try cleaning the throttle body, and see if that helps.
Old May 28, 2003 | 01:51 PM
gla1967's Avatar
gla1967
Wink explorer starts then stops immediately
Figured it out thanks for the info. the IAC was sticking. I ohms checked it and all was fine, but it still stalled, then i just tapped on it with a screwdriver and she started like a charm. I took it off and cleaned out the carbon build-up and will replace it soon.
Old Jun 5, 2003 | 10:48 AM
TOBOY's Avatar
TOBOY
Hey Ford Six...
just wondering, with the idle/throttle plate stop screw... how did you or whoever was working on the truck re adjust it ... any methods & specs to this would be appreciated... As for gla1967's IAC problem.... been there;done that...
Old Jun 5, 2003 | 01:35 PM
steve83's Avatar
steve83
To reset the throttle stop screw, unplug the IAC & start the engine. Then adjust the screw so the engine sputters and dies. When you restart it, it should only run for ~1 1/2 sec before dying again. Plug the IAC back in, clear any codes, and it should be perfect.
Old Jun 6, 2003 | 02:07 AM
Ford_Six's Avatar
Ford_Six
The actual Ford procedure that I got from AllData for that particular year was to adjust the throttle closed, adjust the TPS to a specified voltage, and then open the throttle to another specified voltage. It's been so long, though, I can't fully remember it.
Old Jun 7, 2003 | 06:30 AM
TOBOY's Avatar
TOBOY
Jared (Ford_Six), thanks for your reply ... I'll check if AllData got the info.
& look up the procedure.
Steve83, thanks for your tip as well... I'll try your tip out, hopefully, it works on OBD II trucks.
mototrig
18
Mar 22, 2016 08:22 AM
tdimatteo
Escape & Escape Hybrid
Apr 7, 2015 12:22 AM
Fish13
Nov 1, 2014 08:20 AM
iguana28
Jun 16, 2014 01:45 PM
jakermc
20
Jul 27, 2004 06:19 AM
