Pyrometer reading low
Old Dec 18, 2012 | 02:21 PM
tommyl's Avatar
tommyl
Pyro ga. is reading low, Normal running 200-300, under heavy pull 400-450.
Automeater ga.,,Would it be the ga. or the sender? Are the replaceble separately? '99 F350 7.3PSD
Old Dec 18, 2012 | 02:31 PM
Kdr358's Avatar
Kdr358
Do you have the probe in the driver side exhaust manifold or where do you have it?
Old Dec 18, 2012 | 02:52 PM
snakedoc's Avatar
snakedoc
x2^^^ where it is makes some differences.
but 500 sound like it is in the down pipe.
Old Dec 18, 2012 | 03:13 PM
tommyl's Avatar
tommyl
Have it in the down pipe. Temp in past would read 800-900 on hard pull.
Old Dec 18, 2012 | 03:25 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I would put the probe in the drivers side exhaust manifold or leave that one on the DP and put another gauge from the manifold.
Old Dec 18, 2012 | 03:31 PM
maximusfd's Avatar
maximusfd
My probe was in the down pipe. I moved it to the drivers side manifold and the temps went up about 200 degrees. 70 mph unloaded probe in down pipe ran 500-600 degrees. 70 mph unloaded probe in manifold 600-700 degrees.
Old Dec 18, 2012 | 03:38 PM
jeffreyt's Avatar
jeffreyt
To answer your question, it looks like you can get just the sending unit, but you'll have to check with your specific model. I just googled autometer pyrometer sending unit and the first few links had just the sender. They looked pretty steep, so it may help just to get the kit and replace it all. As far as which is bad, I'm sure you could find a way to check with an ohm meter to see if the resistance is right. It just depends on which model.
But like it was stated above, the DP isn't the best location, so if you have to order a new one, I'd leave the old probe where it is and drill tap the new in the manifold.
Old Dec 18, 2012 | 03:42 PM
Tugly's Avatar
Tugly
Oofda... bare minimum on the level at 65 MPH (empty) with the sensor in the exhaust manifold is 525 degrees. Jumake-a-me nervous with that 800/900 degree reading after the turbo. Ever felt an air compressor tank when running? Warm. Ever touch the open air nozzle? Cold. The pressure drop always cools things down pretty dramatically.
A bad sensor could read low temp, but I wonder about winter with all that cooling down. I notice my EGTs are running a little cooler straight off the engine (with the heavy-huffing 38R) and I imagine a cold blast on the downpipe would cool your breath.
Old Feb 17, 2013 | 06:29 AM
tommyl's Avatar
tommyl
The location of sensor has nothing to do with what the gauge was reading and to what the gauge is reading now. Same location both times, just was not reading up to par!
Gave a shout out to Cory at Autometer, and he replied with suggestions. My problem ended up being my ground wire(at the firewall) not making good contact. Cleaned and reconnected, and we are good to go again.
Old Feb 17, 2013 | 12:34 PM
clem1226's Avatar
clem1226
autometer needs to keep Cory around, he seams to be running the whole show there by himself.
Old Feb 17, 2013 | 01:16 PM
Chris123NT's Avatar
Chris123NT
Glad to hear you resolved it, but move the sensor to the manifold. It's not doing you any good in the downpipe. With the sensor there by the time you read any dangerous temps it will already be too late.
crazer42
Jan 24, 2010 06:26 PM
DNewton
Jan 26, 2007 11:31 PM
Jgold855
Jun 20, 2004 04:33 PM
Twin Tritons
Apr 18, 2004 10:22 PM
