Finally started collecting parts
Old 12-18-2012, 11:53 AM
juni88126's Avatar
juni88126
juni88126 is offline
Well finally started collecting the parts to help the pulling power out on the f350. Bought an ats 088 turbo for the truck. Now I need to start working at getting the exhaust and gauges then it will be time to spend a weekend putting the parts on the truck. The motor has 170,000 I think it still does have the original pump and injectors. Thinking about putting turbo injectors and pump in it while I am doing the rest of the work.
Old 12-18-2012, 01:25 PM
hairyboxnoogle's Avatar
hairyboxnoogle
hairyboxnoogle is offline
Sounds like a solid plan. Something to strongly consider adding to the list might be an intercooler to help make the most of your setup.
Old 12-19-2012, 11:14 PM
juni88126's Avatar
juni88126
I have been able to find the ats parts list. I am needing 11, 14, 19, 21, and 23. Does any have a listing of the actual part numbers, and were I might be able to find them?
Old 01-08-2013, 10:18 PM
juni88126's Avatar
juni88126
I have a question were can I find the screen for the intake on the truck? Mine is missing and the one I got with the turbo was tore up. I work as a heavy truck mechanic and have seen the turbo come apart. With no intercooler the parts would get blown strait into the intake which would not be good. Have not had any luck finding one yet.
Old 01-08-2013, 10:28 PM
ihf-350's Avatar
ihf-350
ihf-350 is offline
I would try an internatioal dealer for the screen
Old 01-08-2013, 11:29 PM
racer30's Avatar
racer30
racer30 is offline
I have one I wont be using cause I will have a Intercooler....Pm me Maby we can trade somthing? I need a Van dipstick for my rear engine MH build If you happen to see one. I have some other stuff too.
Old 01-16-2013, 11:56 PM
juni88126's Avatar
juni88126
Well got the turbo installed, took it for a road test got 10psi of boost,when accelerating. Pyro climbed to 850* and 5psi boost at 80mph with no load on. Still trying to find a cdr tube. Truck does sound good with the new exhaust.
Old 01-17-2013, 12:10 AM
typefour's Avatar
typefour
typefour is offline
Is that the rubber tube from the valve cover to the cdr. If so it is no longer available.
I have all the orings on hand. I am working on the grommet
Old 01-17-2013, 05:40 AM
juni88126's Avatar
juni88126
Yep, that is the part that I need. I was able to find all the other o rings that I needed. I got a pcv valve groomet from the parts store but it is a little smaller then the factory hole so it has been leaking. Also discovered that I am going to have to put another oil pan on the truck here soon, thing is starting to get rust holes in it. That is not going to be fun.
Old 08-20-2013, 10:24 PM
juni88126's Avatar
juni88126
Well getting ready to pull the motor to pull the motor and replace the oil pan and the gaskets. Made a 800 mile round trip to pick up a camper. Camper weighs more then the truck. Truck only saw 4 pounds of boost. Leaked 3 gallons of oil out during the trip. I think while I have the motor out of the truck I am going to put in new injectors, fuel pump, water pump and oil pump in it. Does any one have any pics of a hx35 installed on the ats o88 turbo pedestal. Wondering if I am going to have to cut the firewall to get enough room to install it. the o88 is a tight fit to get it in and out. Was thinking about installing the hx35 and an intercooler while I had the motor out of the truck.
Old 08-21-2013, 12:52 AM
hairyboxnoogle
I doubt you will fit a HX35 on an 088.. not enough room for the compressor. You could with the 093 maybe as it sits at an angle with the compressor in the valley.
Old 08-21-2013, 12:44 PM
Red454sedgwick's Avatar
Red454sedgwick
Red454sedgwick is offline
I would think about a cam while you have it out.
Old 08-21-2013, 02:29 PM
juni88126's Avatar
juni88126
How much larger is the compressor, then the 088 the largest part on the 088 is the exhaust with the bends it has for the in and out sections that are built into the housing. Another thought that I had was to put a body lift on the truck which would give me more clearance for a larger turbo.
Old 08-21-2013, 03:03 PM
hairyboxnoogle
Hx35 compressor housing is considerably bigger than the 088. I dont think a body lift would really help.
Check for drive / boost leaks. Guy i work with has a 90 crew cab that had a 7.3 / 088 and he could hit 20 empty with a maxxed out pump. I only see 10/11 with mine buy my pump is weak and i have one hell of a drive leak where the 'Y' goes into the the exhuast housing.
Old 10-13-2013, 10:35 AM
juni88126's Avatar
juni88126
Still have not done any work to the truck other then attempt to fix some of the oil leaks. Got a promotion at work, so we ended up moving again. Now we live in Elk City, OK. Truck did not like moving the camper down here 4th gear full throttle was 65 mph on flat ground. Found out that my compression tester does not have a big enough of an adapter to test the compression. I am thinking the injectors and pump are the original set. The wife and I went and checked out a local junk yard this weekend and found a 7.3 idi from a 93 or 94 with the factory turbo setup on it. Will be going back in a couple of weeks to get the complete motor, they are asking 400 for it.
Quick Reply: Finally started collecting parts
