Widow-makers
Old Dec 19, 2012 | 07:26 PM
The Horvaths's Avatar
The Horvaths
My boss's (former) father-in-law was killed while driving his car. Went to pass a truck. Wheel's rim blew off the truck. Came through his car and crushed him brutally. Sucked miserably for all involved.
We spent the money on lock ring replacement wheels from AWS in Pasco, WA.
Old Dec 19, 2012 | 08:16 PM
abe's Avatar
abe
Fore those that get Vintage Truck magazine there is a letter from a reader that tells of the writer's father that died in his garage when a split rim he was fixing a flat on exploded in the '60's.
Old Dec 19, 2012 | 09:31 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
Really?? How much air do these tires hold? 40 psi ? I don't see how deflating a tire would be the reason to make it blow out??? These are widowmakers because they came apart going down the road...right? I understand about tires exploding,
I worked for U-Haul Emergency Road Service. I have never heard of deflating a tire, like these old things, and they make the rim blow out. I was airing up a brand new tire and it was to be inflated to 110 psi. I was close and suddenly I noticed a bulge in the sidewall and faster than a blink....KABOOM!!!my ear rang for the rest of the night!
I would be worried about inflating, not deflating.
Bring those to me and I wouldn't even hesitate...
as far as getting them off the rim? They can be a PAIN !
Old Dec 19, 2012 | 09:40 PM
Brian1950F4's Avatar
Brian1950F4
There is a set of wheels on eBay now. Usually the problem I have seen is when reinflating the wm wheels after changing or patching them. We always chained and caged them.
Old Dec 19, 2012 | 09:55 PM
Jeff and Nicolle
Ok I am surprised nobody is lashing out at me yet!
How much pressure were the F-5 widowmakers designed to hold? I really don't know, but now I am curious.
I don't mean to come off as dangerous, but how do you know they are fully inflated? That tells me that you have been close to them, maybe checked them with a guage? I would suggest maybe a 4' x 4' plywood 3/4" thick between you and the tire. and like truckdog(Stu) said stay aside, out of the line of fire.
Old Dec 19, 2012 | 11:38 PM
The Horvaths
We disassembled six wheels last weekend. One (a lock ring) was visibly rusted and scary looking. One lock ring wheel will serve as our spare. Of the four widow makers, one had internal rust and the lip (that is relied upon to hold it together) was crumbling apart. However, that wheel looked fine outside.
I ran over a stinking utility knife blade with my brand new tires today. Now I get to patch one up. Stupid litterbugs.
Old Dec 20, 2012 | 02:26 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Ok, my 2 cents. The big tires hold 80-100 psi, not 40. Rust, road hazards, and metal fatigue after 60 +/- years take their toll.
On the inflation end of things, the widow maker is the only design that doesn't let the technician see whether he has a good lock of the "side ring" on the rim as air is pumped into the tire. Conversely, on "lock ring" style wheels the tech can see whether the ring is properly taking its seat.
On the deflation side, widow makers that start to go flat while in service can twist and deform causing the joint to fail with dramatic results. Thus the stories we hear of incidents as have been described. Stu
Old Dec 20, 2012 | 08:24 AM
tjdad62's Avatar
tjdad62
MarkG,
I removed the cores from my tires and let the air out of them. I then took them to a commercial truck tire store where they used their cage to unmount the tires. I had to pay about $75 including the disposal fee for the old tires. I just wanted to recycle the steel rims but knew I could not do that with the tires still mounted. I didn't have any problem letting the air out and did not fear for my life. I do not believe that an aired up tire is what is holding these rims together, so letting the air out should not have an effect. Or maybe I was just lucky....but lucky on four?
Old Dec 20, 2012 | 08:48 AM
bigwin56f100's Avatar
bigwin56f100
There is no danger once the air is out. Its not like the rims have a "hidden spring inside" Once the air is out there is a small slot to wedge a bar into to start the removal. You do not need a cage to disassemble once the air is out. This is no different than a lock ring tire wheel combo. The lock ring type is still dangerous and you would not try to remove the ring with air inside would you? NO! This rim is the same way DO NOT TOUCH WITH AIR STILL INSIDE
I would NEVER handle one of these off a vehicle with air. I would NEVER remove a tire/rim combo off the vehicle with air still in it.
On the WM I have here I have removed the valve core and CUT the valve stem off so they can NEVER be aired up again.
Old Dec 20, 2012 | 09:05 AM
tinman52's Avatar
tinman52
Welder User
HMMM, just last week I rebuilt the rear brakes on my '68 F 600 with those wheels. I removed the duals and drums as a unit.....lucky I am still alive. I have 3 trucks with wm on them...
Old Dec 20, 2012 | 09:16 AM
truckdog62563
There's plenty of these still in service despite the fact that the last of them were sold in '76 or '77, depending on which reference you go by. Nothing says that each and every one of them is a bomb waiting its turn to go off, but there's enough evidence out there that the risks are far greater with them than any other type rim. Compounding the risk, there's no way to gauge which ones are the time bombs. As a result, they have become a pariah that most reputable shops won't touch. Stu
Old Dec 20, 2012 | 11:08 AM
raytasch's Avatar
raytasch
Believe Nothing
Just my observations but I believe the older they get, the more they are exposed to water, the longer the rust has a chance to grow undetected, the more dangerous they become.
Old Dec 20, 2012 | 11:55 AM
  #28
brkellogg's Avatar
brkellogg
I installed new tires and did tire repairs for commercial and agricultural vehicles for quite a few years in the late 70's. Split rims and lock rings were common on most all trucks larger than a 1/2 ton. I'm fortunate that I never had one come apart on me. I always had a lot of respect for them. I have seen holes blown through cement block walls and through roofs where they have come apart bet never while I was there. In my opinion, there is little danger to handling a tire/ rim thats been inflated for years and there is nothing to fear about a rim coming apart while deflating it. The greatest danger is during the initial inflation after mounting the tire on the rim. A slight misalignment of the rim or lock ring will cause the rim to violently come apart even if the metal is like new. I would continue to use good tires on old rims. But I would update the rims if there was ever a reason to change tires.
Old Jan 12, 2013 | 09:49 AM
  #29
fordf348's Avatar
fordf348
I was just taking a look at my widow makers on my 48 F-3, while the rim and tire is on the truck it seems to me that the tire cannot seperate from the rim, the removable side is on the inside and would catch itself on the drum/axle
Old Jan 12, 2013 | 10:22 AM
  #30
truckdog62563
That's correct. While mounted on the truck, a single wheel style WM will blow its side ring in toward the truck. Stu
