Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Shower drain
Old Dec 18, 2012 | 12:37 AM
ford2go's Avatar
ford2go
Shower drain
A number of years ago, I put plumbed my downstairs bathroom. The house was a year old when I bought it, and had the drains.
I put a shower over the drain that was conuntersunk, and I put the toilet over the pipe that was sticking out. (Made sense to me). There was also a drain pipe on the other side of the wall that I tapped into for the sink.
Anyway, the shower kit instructions just said to mount it on a waterproofed base of plywood or whatever. They said just to cut a hole in that base for the drain. Didn't seem like a real good plan, but I did that.
I never could tell if the drain leaked out, but the front edge area always looked wetter than I thought it should be. It could just have been from the shower itself getting past the curtain. (My son was the only one who generally used the shower, so I really never paid too much attention).
I'm thinking of replacing it now, and I'm wondering if there's a better method for the drain. I've loooked in a few books over the years, and they never seemed to cover that subject in any detail.
Hoping that somebody here has the straight scoop.
Thanks,
hj
Old Dec 18, 2012 | 12:42 AM
85e150's Avatar
85e150
Put in tile and be done with it. They hot mop the whole thing so it can't leak at the drain. Then the tile goes over that whole mess.
Serving suggestion......
Old Dec 18, 2012 | 08:16 AM
cracked block's Avatar
cracked block
There are different ways to go about this. If you are using a pre-formed shower pan then the drain goes over the 2" pipe coming out of the floor and is usually tightend with a neopreme gasket. If you go with a liner than the liner goes over a clamping ring mounted to the drain. Hope this helps, keep us posted.
Old Dec 19, 2012 | 12:10 AM
ford2go's Avatar
ford2go
Thanks guys,
Unfortunately, there's no pipe coming out of the floor. IIRC ( it's been well over 10 years), it looked like the floor drain under my laundry tub. My guess is that I'd have to somehow put a pipe in it.
If I ever get to it, I'll post what I tried -- I tend to work at the speed of smell.
hj
Iaff113
2011 - 2019 Explorer
Dec 19, 2018 02:05 PM
Turbo Dog
Garage & Workshop
15
Sep 8, 2015 02:06 PM
blowhole
Jul 9, 2010 07:34 PM
deadbug
6.4L Power Stroke Diesel
16
Mar 11, 2009 05:51 PM
cpe41
Garage & Workshop
Aug 8, 2008 11:26 PM
