Well for my winter project I have decided to tear out and re-build my 390 because it is gutless. So after tearing it down and figuring it out, I have found my motor to be an emissioned up truck motor with 7.92 to 1 compression. In order to build the motor up I am planning to cam it up and increase the compression. I was thinking of getting earlier car pistons which should bring the compression up to 9.47 to 1. Also I am planning to run this cam. COMP Cams Xtreme Energy Cam and Lifter Kits K33-238-4 - SummitRacing.com
I just wanted to know if anybody saw any red flags with my plan before I ordered my parts. Also do you all think I might be going too big with this cam. I have stock port heads with a edelbrock dual plane intake and long tube headers.
You might want to have the rods re-bushed. I assume you are going to install new bearings and rings? Do you already have headers and 4 barrel intake? 360 pistons bring the compression right up too (probably the same piston).
If you want more power get a 428 crank. If you want even more, contact survival motor sports.
Yes, check out 360 pistons - the pin height is different, making the piston sit up higher in the bore, increasing the compression, I think to around the 9.5:1 or maybe 10? can't remember
It looks good to me, I am building the same engine, 390 with 360 pistons [H395P] ,edelbrock performer and try-y headers, also that 33-238-4 [XE262h] camshaft was recommended by Comp and a local engine builder for my 1976 Highboy with manual trans, 410 gears and 35" tires. The guy's over on the FE forum said I should keep the duration at .050 below .220 which meant the XE256H would be the correct cam choice for my build and that is what I ordered but the XE262H showed up this weekend instead [I think Santa wants me to run the bigger cam] so it's what i am going to run.
Well thanks for the responses. It sounds good so far and I went to order the parts today and ran into a slight snafu. I got to double checking the pistons before ordering and found out I can order two different sizes which will yield either 8.98 to 1 compression or 9.8 to 1 compression. I would like to go for the 9.8 to 1 but need to know if they will let me run on 93 octane fuel without detonation. I dont mind running 93 in the truck, but I dont want to have to add fuel conditioner.
