stiff door lock
Old Dec 17, 2012 | 02:46 PM
mike L's Avatar
mike L
stiff door lock
Hi, My door lock doesn't work very well. It is VERY hard to turn the key, both ways. It broke the plastic piece behind it, it hooks to a vertical metal rod. I replaced the plastic piece, and switched locks. So it's not the lock cylinders. What does the metal vertical rod hook to, that's making it hard to unlock the door?
Old Dec 17, 2012 | 02:50 PM
deere55's Avatar
deere55
I had the same problem. In mine, the actuators for the power locks were frozen. I unhooked the actuators, but left the connection between the key and the actual lock, so I now just have non-power locks, but it's better than no locks at all.
Old Dec 17, 2012 | 08:34 PM
Bob_Smith's Avatar
Bob_Smith
Had both this problem and stuck key lock mechanisms on my truck when I got it. Since you replaced the locks already I'd put money on the actuators being your problem.
Old Dec 18, 2012 | 11:57 AM
mike L's Avatar
mike L
Thanks, I'll try that.
Old Dec 18, 2012 | 01:06 PM
mike L's Avatar
mike L
Door latch
sorry guys it doesn't have power doors locks.
It looks like both door latches are starting to jam up. I tried wd40 it doesn't help. I can't find latches at advance auto??? dealer item i guess.
Old Dec 19, 2012 | 12:37 AM
Bob_Smith's Avatar
Bob_Smith
You might try taking them off the door and letting them soak over night to see if that helps. LMC has them but at that price I'd suggest trying a junk yard and see if you could find some in good shape there. Hell I'd just get another door before I payed that.
Old Dec 20, 2012 | 08:02 PM
mike L's Avatar
mike L
What would you soak it in?
Old Dec 20, 2012 | 08:06 PM
deere55's Avatar
deere55
Probably PB Blaster
Old Dec 21, 2012 | 07:49 AM
Bob_Smith's Avatar
Bob_Smith
I've soaked that type of stuff in PB Blaster or CLP in the past to get things loosened up and had good results. Just take a plastic jug/bowl put the part in it and put enough in to cover the part and let it sit overnight or a day or 2 as needed. That usually does it, and if it doesn't you're usually just out of luck and need to replace.
Old Dec 22, 2012 | 05:30 PM
mike L's Avatar
mike L
fixed latch
Thanks, I finally got it to work, with about 1/2 a can 10d 40.
Old Dec 22, 2012 | 05:38 PM
Bob_Smith's Avatar
Bob_Smith
No problem at all, glad to hear you got it workin man!
Old Dec 22, 2012 | 06:16 PM
Eddiec1564's Avatar
Eddiec1564
Better use some spray on white grease, WD40 will evaperate and your back to a sticky lock. Been there and done that.
2000PrettyBaby
1997 - 2003 F150
Dec 23, 2016 10:00 PM
Aus56
Jun 28, 2014 06:35 AM
adamkat22
Dec 13, 2013 06:04 AM
BroncoFan74
Mar 11, 2013 05:02 PM
