The ULTIMATE Pick n Pull Score!
I am usually on the slick forum with my 1966 F100 but have been lurking on here for a while as well. I have my 66 torn down to the frame for a complete rebuild. In the meantime I have found that I still need a truck to chase parts and do other assorted truck duties. So about a month or so ago I started shopping for another pick up. I came across this 1969 F250 Camper Special on craigslist offered by my local pick n pull. went down and took a look at (3 Times). On the third trip down, I bought it! It has a (I Think) a 390-4 barrel with a C6. Runs decent but needs a little work. The rockers are tapping but that could be due to the low oil level. It also has a missfire about every 12 seconds, especially under a load. Been a while since I have had an FE but I figure I can figure it out with the collective knowledge on here.
Here a few pics:
It reminds me very much of my story, and the truck I got a couple months ago. Good for you!
Bob
Anyone have any ideas what could cause the engine to misfire about every 12 seconds and it gets worse under a load when in gear? I can't hear any bottom end knocking. But that doesn't mean anything.
When I bought my '67 years ago, someone had swapped two plug wires on cap(forget which two now, they were side by side), but it would not run over 35 mph without bucking and carrying on. I never thought to check firing order, but after tinkering for a week and not finding it I finally though..>Hmmmm. Yup, two wires were swapped. Moved them back and it purred like a kitten.
I think Hio Silver has a good complete check up list some where. Maybe he could re-post it if he reads this.
I think HIO Silver has a good complete check up list some where. Maybe he could re-post it if he reads this.
Here's what I do to every new-to-me vehicle. Doing some of these simple steps when looking at a vehicle to buy can also reveal stuff the seller may not tell ya.:
Preserve Sanity.
Grab a trash bag and a small box… trash and garbage goes in the bag and any spare parts goes into the box. The owners manual and, if present, fuses goes in the glove box.
Powerwash the body, wheel wells, and even the engine compartment.
Vacuum it out.
.....Cleanliness is next to…. and I'd rather work on a clean rig.
Basic Visual Inspection
Grab a note pad and do a bumper to bumper visual inspection.. this is also time to go on “Hack Patrol” – All those so-called “repairs” made by previous owners. Look for duct tape, household wire nuts, electrical tape, wood screws, wires that go to nowhere.
On the notepad make three columns/categories:
- Gotta fix/replace now.. these include safety items like lights and brakes, cab mounts;
- Gotta fix/upgrade/replace soon or “The Watch List” – floor pans.; and,
- Fix later – rust holes, old wiper blades, loose ***** and switches.
Look for loose, missing, or broken hardware like lug nuts, fender and bumper bolts, and bellhousing to engine bolts. Feel around for soft or cracked hoses – radiator hoses degrade from the inside. Crimp it with your hand and it should have the same firmness all the way around.
Fluid Check
You’re just doing this so ya don’t burn anything up and the fluids will be replaced later.
Engine oil, coolant, auto trans, power steering, and brake fluid. If possible, front and rear axle lube, T-case, and gear lube in a manual trans.
Air up the tires and the spare.
Hardware Check (Bumper to Bumper)
With a screwdriver, sockets, and wrenches, double-check the tightness of everything that is easily accessible.
Torque the lug nuts.
Tighten hose clamps in the engine compartment.
Mechanical fan bolts, valve cover, exhaust manifold, brackets, seat brackets, steering wheel, hood hinges,... even the license plates. Everything.
Double-check spark plugs and seat the plug wires. I like to also verify the firing order.
Pre-Operation
Check for brake pressure... gotta have some pedal.
Turn on the ignition system (no engine start). Turn on everything - blower motor, exterior and interior lights, turn signals, hazards, heater controls, wipers, etc.
Engine Start
With a fire extinguisher at the ready, fire it up, to let’er cook.
Verify that the thermostat works by leaving off the rad cap. You’ll see the coolant flowing which is an indication that the thermostat had indeed opened.
Take it for a test drive and note how it tracks, turns, accelerates, and stops.
Park it and let it idle for about five minutes to check if it overheats.
Shut it off for 10 minutes and then restart it. Hopefully it starts right up. If not, then it can be a vapor lock, a carb that needs to be rebuilt, or defective ignition components like an ICU or coil.
Full Tune Up (to establish a baseline)
Rebuild the carburetor!!!
Replace points, plugs, wires, cap, and rotor.
Change the engine oil and oil filter.
Change coolant, axle gear lube, transmission, & T-case lube.
Replace air and fuel filter
Set timing, dwell, and idle speeds.
Bleed and change brake fluid.
Replace all the drive belts and at least the radiator hoses.
Take a grease gun and service all grease fittings.
Lube door latches, locks, tailgate latches, door hinges, etc.
...load-check the battery and replace if necessary.
70-360fe - I have seen that where people put new stuff on the car and then it ends up in the yard a week later. Have scored a few good parts that way.
HIO Silver. Excellent Task list you have put together. I have a similar list myself. I also hate working on a dirty rig. Very rarely do I buy a vehicle on the first visit to see it.
Mike, The Fe is tapping at all idle speeds. I am hoping its just low oil level. I will know more tomorrow when I get her home.
Here's a link to my 66 F100 Project. This is why I had to buy another truck. I "needed" it. At least that's what I told my wife
https://www.ford-trucks.com/forums/1...e-waiting.html
