Fuel pressure
Old Dec 16, 2012 | 05:41 PM
Iaff113's Avatar
Iaff113
Fuel pressure
Hey im looking to put a gauge on my truck, does anyone sell any decent kits? Or does anyone have their own set up the want to show?
thanks
Old Dec 16, 2012 | 05:56 PM
jedlicka87's Avatar
jedlicka87
I just order parts to do this same thing. I have an Edge CTS for my guages tho so thats what i am going to go with. But i did get a guage from Glow Shift for my coolant pressure and its nice but i think the pressure sensor will be too fat to install in the stock test port, not sure tho...
Old Dec 16, 2012 | 06:02 PM
Iaff113's Avatar
Iaff113
Well I have the CTS also but I dont have the expandable cable, guess I can go that rout? but then How do you do it?
Old Dec 16, 2012 | 06:12 PM
jedlicka87's Avatar
jedlicka87
Edge Products| Products
Part # 98605 AND 98607, or any 100 psi sensor would work as long as it fits. Then youll have to take your Egde out and connect it to the Edge MyStyle on your computer and make the custom names and whatnot... I have yet to do this so I'll have to read up on it myself, but those are the 2 things i just bought.
https://www.ford-trucks.com/forums/1...ure-guage.html
FYI, I dont thinks this is the cheap route, but I like the "clean" look of no guages on the A pillar...
Old Dec 16, 2012 | 06:24 PM
mustang_309's Avatar
mustang_309
I hooked up a fuel pressure gauge to my edge insight CTS and it was very easy. But like you I didn't have the expandable EGT probe, when I bought my CTS the place I bought it from didn't tell me about the EAS (edge accessory system) so I had to get another EGT probe that comes with the EAS starter kit. So it was fairly expensive, but you don't have to mess around with splicing wires or trying to figure out where to mount the gauge. I just bought the fittings and hose I needed from evco house of hose, m12x1.5 to jic goes into the fuel filter housing and ran the hose over to the drivers fender and went jic to 1/8" npt for the sensor and the daisy chain connection on the EAS is very slick.
Old Dec 16, 2012 | 06:28 PM
mustang_309
You have to hook up the EAS and plug everything into the CTS and power it up before you do the mystyle setup that way the CTS knows you have the EAS before you configure your sensor in the mystyle software.
Old Dec 16, 2012 | 06:49 PM
Iaff113's Avatar
Iaff113
so you didnt go with the whole set up off the site?
Old Dec 16, 2012 | 06:53 PM
jedlicka87's Avatar
jedlicka87
I went with The EAS Universal Sensor Input and the Edge’s EAS Pressure Sensor. the damage was $292.
Old Dec 16, 2012 | 07:03 PM
Iaff113's Avatar
Iaff113
ok well I will need to get the starter kit also and figure out how they all connect, does the pressure sensor thread right into the fuel bowl
Old Dec 16, 2012 | 07:07 PM
mustang_309
I bought all the stuff for the CTS I needed from Edge but the stuff to connect the pressure sensor to the filter housing I bought at evco house of hose. You can buy the m12x1.5 to 1/8" NPT from autometer online and im sure other places have it as well but I didn't want to wait for the mail so I just bought the stuff from evco.
Old Dec 16, 2012 | 07:12 PM
jedlicka87's Avatar
jedlicka87
You will need that starter kit, then everything will plug into eachother. I believe you can plug upto 8 accessories together. Then youll need this adapter to screw into your fuel pressure test port. Ford 6.0L Powerstroke Fuel Pressure Gauge Adapter Fitting
Old Dec 16, 2012 | 07:17 PM
jedlicka87's Avatar
jedlicka87
I also picked this up so i can mount the sensor of the drivers side fender like mustang_309 said.
JEGS Braided Stainless Steel Mechanical Gauge Hose Kits - JEGS
Old Dec 16, 2012 | 07:32 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
I used the glowshift led, without a remote adapter at first. The pressure sensor was a tight fit, so i ordered the extension to move it away from the engine.
Old Dec 16, 2012 | 07:40 PM
mustang_309
If you use that fitting that Jed linked you can thread the sensor straight into that and right into the filter housing, the harness that comes with the sensor is like 8' long so you can easily reach the fuel filter housing from the cab. I think doing it that way would be easiest but I couldn't find that fitting locally when I did mine so I had to come up with something different.
snorindad
Jul 30, 2017 10:36 PM
caere
Jul 29, 2011 11:07 PM
jetact
Jun 28, 2011 12:47 PM
caere
Sep 30, 2010 05:04 PM
wdj
Mar 17, 2004 10:15 AM
