little help with my FE
Old Dec 16, 2012 | 04:42 PM
78GryGhost's Avatar
78GryGhost
This is what i got trying to find what flywheel i need. After looking at some #'s i'm not even sure what motor i got now. it has a Edelbrock 390 Performer intake on it.
Block cast # C8ME
Head cast # C8AE-H
Date code 5J10
The flywheel that was on it was D2TE-6368-BA but its two big for the bellhousing i got for the NP435 its rubbing on the inside of it and the starter wont line up with it.
Old Dec 16, 2012 | 07:03 PM
1972RedNeck's Avatar
1972RedNeck
It's definitely a FE. Good luck on the rest.
Old Dec 16, 2012 | 07:29 PM
78GryGhost's Avatar
78GryGhost
alright thanks! i'm just wondering if i can put a 390 flywheel on it and call it good.
Old Dec 16, 2012 | 07:30 PM
78GryGhost's Avatar
78GryGhost
since they are internally balanced except the 410 428 right?
Old Dec 30, 2012 | 12:07 PM
SuperSabre's Avatar
SuperSabre
Just to confuse the issue, I looked in Steve Christ's Big Block Ford Engine book, Chapter 3 - if he's right, your C8AE -H heads were used on '68 (and presumably later) 360/390/428. Your C8ME block was used on '66 - '70 428s (and some FT engines). If I were you, I'd check the stroke to see if it's 3.78 for a 390, or 3.98 for a 428. If it's the 428 then it has to be externally balanced. The 5J10 date code doesn't seem to fit. Don't know what to say about that. Good luck!
Old Jan 2, 2013 | 05:48 PM
78GryGhost's Avatar
78GryGhost
i bought a stock 1976 Ford 390 flywheel put it on the there buttoned everything up and started it. there were no vibrations from the motor so i assume its a 390. thanks for the info on this.
Old Jan 2, 2013 | 11:40 PM
FordmanShane's Avatar
FordmanShane
congrats! a running 360/390 I think you can measure the stroke with drill bits...
tylstruck
Feb 18, 2008 02:22 PM
crazyredneckanyhow
Jul 13, 2007 01:37 AM
chinaman
May 8, 2006 10:02 AM
motorhead_83
Apr 12, 2004 06:16 PM
