Flywheel interchange
Old Jul 10, 2007 | 11:15 AM
crazyredneckanyhow's Avatar
crazyredneckanyhow
Hey guys i just got another highboy but no motor. Ive gota good 390 and the guy left the 428 flywheel in the truck. So my question is will the auto flywheel off a 428 work on my 390?
Old Jul 10, 2007 | 02:22 PM
sowder's Avatar
sowder
Don`t think they interchange 428 is externally balanced and the 390 is internally balanced
Old Jul 10, 2007 | 03:08 PM
62_Galaxie_500's Avatar
62_Galaxie_500
You might (???) be able to use the 428 flywheel if you have it neutrally balanced.
Old Jul 10, 2007 | 05:19 PM
crazyredneckanyhow
Thanks guys for the info. The donor truck has a new clutch kit and all that so ill prolly jsut swap in the 4spd while im at it. Not the first time ive done the auto to standard conversion. Just dont have time to search for parts or have any work done.
Old Jul 10, 2007 | 07:10 PM
Bear 45/70's Avatar
Bear 45/70
Flex plates as they are called are cheap and it will cost you more to have the 428 piece balanced that buy one new.
Old Jul 13, 2007 | 01:37 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
Yes if you take the welded on balance weight off then have it neutral balanced.
It's worth more to a 428 person but you must know which weight it has for the application. I recall 11 and 13 tooth count long weight differences.
This weight can be welded on a 390 plate if you index the position as 428 plates cost more than 390 plates.
Even a wasted 428 plate is a keeper to use to locate the weight position then transfer to a 390 plate.
Millam
May 21, 2015 01:41 AM
ScallyWaggler
May 16, 2015 02:03 AM
73 ford guy
May 20, 2014 06:43 PM
wxo
Nov 10, 2007 10:33 PM
MR_J_DAHMER
Nov 29, 2005 12:16 PM
