I first put this on the diesel site, but thought this would be a better place to get help.
Have a new one for you. I replaced the battery in my keyless entry door pad and programmed it for the default code. Everything went fine, except now my key fobs won't work.
I tried to reprogram them with the usual method of switching the ignition on and off for 8 times, however, the locks won't cycle after the 8th time.
Any ideas?
