Engine won't line up with engine tower
Old Dec 14, 2012 | 12:29 AM
vincel1965's Avatar
vincel1965
Attempted to install the 302 but engine mount doesn't line up with the tower on the driver's side. The tower is off about 2 inches toward the cab.
Old Dec 14, 2012 | 04:24 AM
jowilker's Avatar
jowilker
The chassis have multiple mount hole sets, can you adjust the perches to different holes? While a 302 wasn't offered in a slick, the frame rails are pretty much the same layout from 65-79. Many 302s have been installed in slicks so we know it will work.
As long as you have 68-79 Ford 302 or 77-79 351/400M perches you should be able to make it work.
Looks hi-end so far.
John
Old Dec 14, 2012 | 05:54 AM
Pickupmanx2's Avatar
Pickupmanx2
You will need to unbolt the engine perches, and move them towards the front of the truck, 3 bolts each side, holes are already in the frame.
Haydcarpenter
Feb 16, 2018 06:51 PM
Oldcrowbarber
Jul 28, 2017 08:28 PM
tarcol
Mar 13, 2009 04:49 PM
75HiBoy302
Jan 31, 2003 04:50 AM
