WOW thats a great write up thanks a ton. Just what i had been looking for. Looking like fri or sat i will be doing it.
Is the valve cover gasket removal nessacary for the gp removal though like he mentioned ? I don't see why it would be, id just hate to remove it and encounter a problem douring removal or install. I don't have a problem removing it just don't want nothing to break lol. FIRST TIMER HERE and its at 230kmi and i can imagine things are brittle
Other than that, its fairly straight forward and I'm certain it will go fine....... All thanks to y'all and FTE
You don't have to remove the VC gaskets. Use a few finger tight VC bolts to keep them in place while you work on the GPs. Keep track of where the VC bolts with the top studs go back in. You should unplug the UVCH and look at the pins. Make sure the center pin isn't getting burnt. If you are going to do the 50 cent mod you have to pull them apart anyway. There is nothing real complicated, just time consuming.
Great brother thanks for all the awesome help. Let ya know how it goes.
