Ok I have an 86 f250 with the 460 and my hc is triple the allowed I have not seen a cat on this truck it is carbed so no o2 sensors and no computer to speak of closest thing to a computer is the ignition control module and I had it tested and it passed did this truck come with a cat and if not would it fix the problem if I put a universal on it?
I picked up a '86 F150 with a straight six and a one barrel carb. It failed the New Mexico emissions test the first time I took it thru even though it had a cat in place.
The problem was the carb (dreaded feedback carb) needed rebuilding and I'm not sure what condition the cat was in.
I replaced the carb and ignition system with a Duraspark II system and a 600cfm vacuum secondary Holley carb. Then added a dual exhaust with two universal cats.
Even without rejetting hte carb for our higher altitude, the truck passed on both idle and cruise.
I think that I was nearly 10x over the limit on idle the first test and several times over the limit on cruise.
The air pump on mine had been previously disconnected and I removed it completely, so there is no additional air pumped into the cats.
Your truck should not have a cat, the emission label should look like mine. Note the large NON-CATALYST wording. I don't believe the 460 was available on an under 8500 GVW truck in 86. If your HC is high, it is probably carburetor rebuild time, either a failed power valve or leaking accelerator pump tube.
Why do you think a catalytic converter will clean it up? If it's burning rich, that will just overheat the cat and melt the guts and clog up the exhaust. How does it run?
dragonisfury, does your truck have the Thermactor system (air pumps) installed and functioning correctly? I am pretty sure that is what Ford used to clean up the exhaust on these. Also be sure it is being tested for the correct weight class. I seem to remember the idle mixture setting on these was a royal PITA to do according to Ford's procedure. I can't find a copy, but I seem to recall it used a propane enrichment. If I can find my 86 emissions manual I will try to scan and post the procedure.
Yes, some 460's even had two "air pumps". This would be the system I'd check as well.
Ford did use a propane enrichment proceedure on all their carbs for adjusting the fuel and idle mixtures. Pain in the butt. You can get better results using the Smog stations tail pipe probe, or using a vacuum gauge proceedure.
Mine had the two "smoke grinders" on it, one fed 6 of the 8 exhaust ports (ones at the crossover had undrilled "nozzles"). The other one fed all 8 at the manifolds through a stainless steel "spider". If one or both are missing you probably will have high hc.
Is everything in your distributor, vacuum and centrifugal advance working correctly, these engines use a complex set of vacuum plumbing, the end result though is warm you have vacuum on the distributor advance all the time. If they are doing a run up type check rather than just at idle that will kill you. Since I don't have emission testing here, I don't know what the procedure is.
Setting the mixture by vacuum will give you too rich a mixture which will cause high hc. One trick the Turbo Mopar bunch used to do to get some of the T2 engines through and I have seen it used other places too, fresh oil change, new PCV valve and take it right in for testing.
Does your truck have the electric pumps or an engine mounted mechanical one? If the mechanical one make sure it isn't leaking into the engine, that will kill the hc test as the PCV system is sucking gas fumes.
If done incorrectly you are right. Set mixture to highest engine vacuum then back off the mixture toward lean 1/2 to 1 full turn. This should get you in the ballpark. Preferably toward lean just before lean misfire occurs before doing your test. Tail pipe sniffer is the best "modern" way.
Yes, very dirty oil will cause high HC, even if the vehicle is running correctly.
I have never seen a factory system with both types of pumps. My timing cover had the hole but no pump from what I remember. One of the fuel pump bolts held the lines to the timing cover.
The 460 and the 400 could have both. In-tank pumps to circulate the fuel, and a mechanical pump to bring it up to the carb.
1st I have heard of this too. The ones I am familiar with had one pump in each tank, and the orifice return thing at the carb. But knowing Ford and the wacky stuff they did, who knows what could be on these trucks.
