'86 F150 Emissions question
I'm new to the forums because of an issue I'm having with my truck. I was hoping some of you experienced guys out there might be able to provide some input.
My truck:
The truck is a 1986 F150 with a 351W + 4BBL carb. From what I gather, that was the pretty standard equipment. I bought it from a kid who fancied himself the closet mechanic. In the process of his "work" he ended up removing most (if not all) the emissions equipment installed on the pickup. (Can't find a catalytic converter on the exhaust line either)
It runs rough until it gets warm. Once warm, it doesn't necessarily purr, but it works like a champ and has power to spare. I accelerated up a hill one day, carrying 1100 lbs of garbage on the way to the dump.
When I turn it off, it does smell like it is running slightly rich.
Sounds like a great project, eh?
My Problem:
Thing is that I'm in the middle of a home remodel and am in need of a hauler right now. It's been about a year since I made the purchase and the tabs have come up due. Now I have to pass the dreaded emissions test. Due to scheduling conflicts, I asked my Dad to take it in during one of his off days. The truck failed by a small margin: exceeding CO2 limits 560ppm (allowed: 280ppm) on idle test only. It passed the cruise test with no issues.
My dad, being the go getter he is, took it down that very day to a "Certified Emissions Specialist" as directed by the emissions center. They told him the carb was "shot," that it wouldn't hold an adjustment and it needed a new/rebuilt carburetor. Then they quoted him an obscene price that I won't bother repeating here. They wouldn't even guarantee an emissions pass with the new carb installed.
I've been planning on doing some work and replacing some equipment in the future anyway (including the carb) but coming up on the Christmas season during a remodel is not exactly the time I hoped for this: both spare time and cash are at a premium these days. Additionally, considering this shop was quoting such a high price for the carb, I'm a little suspicious of their claim that the carb is totally unworkable. I've had individual dealings with this shop before and they're always on the high side of estimates for work.
So I ask you guys - without looking at it, are there any adjustments I can make which will help increase the chances of me getting it to pass emissions the second time, or should I bite the bullet right now and install a new Holley from Shucks?
Any info would be greatly appreciated. Thanks!
If I were you, I would go to JEGS High Performance - Your source for Edelbrock MSD Holley Mr. Gasket Moroso or Summit Racing - High Performance Car and Truck Parts | 800-230-3030 and look at their carbs, and buy a new one. I know that edelbrock sells some that are jetted a little leaner for emissions, I am not sure if Holley sells some that are a little leaner. Anyway, that's probably going to fix your problem, and make it run better and get better fuel mileage too.
I'm sure you ment that the CO was to high not the CO2. CO2 (Carbon Dioxide) is good all engines even the cleanest ones pump out lots of CO2. CO (Carbon Monoxide) is highly regulated, it is toxic and the result of incomplete cumbustion [fuel HC (Hydrocarbons=hydrogen and carbon) combines with oxygen O2 to form CO2 and water H2O] generally from the engine running to rich. The solution is to simply adjust the fuel mixture at idle to lean it out a bit. This is generally really easy I am not sure what carb you have (probably the holley) idle mixture is adjusted with two screws either on the side or base of the carb one on each side, the easiest is to turn it in until the engine starts to stumble and then out a 1/2 turn, even better is with a vacuum gauge and adjust for leanest with highest vacuum. This should be done with the engine up to temp and in gear if it's an automatic.
Hope this helps
Turning the idle screws is a good idea too, if they are not capped off by the factory.
I had real good luck rebuilding my carb this past spring.
I can see the plugs over the idle screws are still set, so the carb is per-production. I figure if I'm going have take the carb off to chisel away the plugs, I may as well just install a brand new Holley with the screws located in the proper place and not dull my chisels.
So that one is out. I brought out the Chilton's manual and began following their carb tune up method from step one. You basically have to turn the engine on and off (on and off, and on and off . . . .) to maintain fuel pressure in the reservior while alternatively adjusting the fuel level manually. The fuel level was set pretty high at the onset since it would gush out of the fuel level viewport screwhole. Hopefully this means it was just dumping too much fuel into the engine, hell if I know.
Don't notice any change in driveability. We're experiencing winter weather now, so I see lots of exhaust condensation; but it doesn't deposit any soot on a white paper towel. I know that 560 ppm of CO won't darken the towel, but it's reassuring that I didn't make things worse.
So I guess it's going to come down to a emissions test, since I don't know where else to go to test my handiwork.
Took it out on the highway this afternoon once I finished and opened up all four barrels. I don't know what it is about this truck, but I just love to drive it.
If so, is it in fact CO that was high?
Catalytic converters exist to turn CO into CO2. (carbon monoxide, which will kill you quickly if not poison you irreparably, vs. carbon dioxide, which will only kill you slower, and is quite enjoyable in Diet Coke and other beverages...)
If you don't have a cat, you are not going to turn CO into CO2 regardless of mixture.
Were there other tests for HC & NOX? If so, what were those numbers?
If you passed on those two, your engine is running fine (fine enough for the emissions test, I note your other issues of rough cold running which may be fixed with the idle adjustments etc) But even if you are running fine, you will not eliminate CO without a Cat.
