As usual I need help....I just tested my FICM and voltage checks were good. The problem is I had my block heater plugged in. Would that fact give a false or good reading ? And should I unplug it and check again, and if so how long should I wait before checking it again? The outside temp here is dropping and it is currently 40 degrees. Thanks in advance for the coming help. Someone always pulls my fat out of the fire.
Block heater has no effect or impact on FICM. Totally separate. Only effect might be less current draw while cranking engine to start cold. If your batteries are good, that won't be an issue. FWIW it's currently 17 degrees here, and I won't be plugging my 6.0 in tonight...
