Water Drain plug need help
Old Dec 12, 2012 | 05:22 PM
Sparky83's Avatar
Sparky83
Hi... first time posting in the 6.0 section... i really need some help...
i just bought this truck couple months ago... and ive been going around it doing all the maintenance stuff ive discovered hasnt been done in awhile... well heres where my problem is... apparently in some point in its history... one of the previous owners replaced the water drain/fuel pressure relief plug with a soft brass plug.. well ive been trying for the last 4 days to get this plug out.. and its fighting me at every stop...
the little nub in the center came right out...
but the outer plug... i cant get to budge at all...
tried the e-z out people suggested would work.. but hasnt come out.. and all i did was manage to bend the tool that holds onto the e-zout... and the wrenches just round off the corners on it...
Old Dec 12, 2012 | 05:28 PM
sammy77's Avatar
sammy77
I ended up replacing the cover on mine when I could not remove it. Also, make sure you replace the plug with this:
Ford part number: 6E7Z-9C082-A
International part number: 2589259C91
Old Dec 12, 2012 | 05:38 PM
Sparky83's Avatar
Sparky83
Originally Posted by sammy77
I ended up replacing the cover on mine when I could not remove it. Also, make sure you replace it with this:
you can get just the manifold part?? do you remember how much that was??
Old Dec 12, 2012 | 05:47 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
The new manifold will not have the fuel heater that your 04 has. Seems there might be another harness for it, ( I don't recall for sure) or zip tie that plug up out of the way.
Ford did away with the fuel heater on later years.
Old Dec 12, 2012 | 05:48 PM
Sparky83's Avatar
Sparky83
heater thing what the orange plug went to??
Old Dec 12, 2012 | 05:50 PM
amdriven2liv
That is the updated drain plug to put in the new manifold!
Old Dec 12, 2012 | 05:52 PM
nylyon's Avatar
nylyon
Looks like they're going for a little over $100 now 6C3Z-9B249-B
Get that updated plug too.
You *can* take the cover off and see if you can remove the plug on the bench, worst case you have to get a new cover anyway.
Old Dec 12, 2012 | 05:57 PM
Sparky83's Avatar
Sparky83
had a friend send me the updated plug... thats why ive been trying to get that one out... that and i dont want to have to change the water filter again the messy way like i did last time... the bowl was still full when i took the other cover off last time...
Old Dec 12, 2012 | 05:58 PM
sammy77's Avatar
sammy77
IIRC, it was $100
Old Dec 12, 2012 | 06:00 PM
amdriven2liv
I think this is the right part number now. It has changed a couple times
First it was:
6C3Z9B249A
Then :
6C3Z9B249B
Now
6C3Z9B249C
The tSB from a time ago shows B
File Type: pdf
Old Dec 12, 2012 | 06:01 PM
Sparky83's Avatar
Sparky83
whats IIRC?
sammy77's Avatar
sammy77
Thanks, fixed it!
Old Dec 12, 2012 | 06:02 PM
sammy77's Avatar
sammy77
whats IIRC?
Sorry, If I Recall Correctly.
Old Dec 12, 2012 | 06:03 PM
amdriven2liv
If you enter it into Tousley's search engine as the "B" it comes up as old part# and then becomes "C".
Ford Parts - Tousley Ford Parts Depot
Old Dec 12, 2012 | 06:09 PM
Sparky83's Avatar
Sparky83
ahh... i was thinking it was another acronym.. like the HFCM.. only found out what that meant 2 days ago...
