View Poll Results: gaskets or not
yes
33.33%
no
66.67%
Voters: 3. You may not vote on this poll
gaskets or not?
Old Dec 12, 2012 | 03:35 PM
thewestie's Avatar
thewestie
gaskets or not?
I'm getting ready to put my 5.8 motor together. I was wondering what other experiences were.
I'm tossing back and forth the idea of no gaskets on the new manifolds mated to new cast iron heads. I've read that with no gasket theres nothing to leak. I did it once on the same set up but unfortunately 5000 miles after a ground up restoration of a 93 f250 someone crossed the double yellow and it was totaled so I have no way to judge the long outcome.
So my question is gaskets or not.
Thanks Steve
Old Dec 12, 2012 | 08:54 PM
Beanscoot's Avatar
Beanscoot
Gaskets on manifolds
Ford does not use gaskets between the exhaust manifolds and cast iron heads. A bit of graphite grease was used in the old days.
I haven't had any leaking issues even with decades old engines.
It is important to insure the manifold surface is in good condition however, so if there is pitting etc. the surfaces should be refaced.
The disadvantages of gaskets are that it is possible to break off the "ears" of the manifold flanges from overtightening, and if the gaskets fail over the years the urge is to tighten them up. Unfortunately the parts of the gaskets under the ears often disintegrate, so that when the bolts are tightened the ears are forced to bend, which of course doesn't work with cast iron.
Also, with the gaskets it is much more likely that the iron surfaces start to corrode as they get exposed to the air.
Old Dec 13, 2012 | 07:37 AM
baddad457's Avatar
baddad457
Depends on the mating surfaces, if the manifolds have been milled first and the head surfaces are good, then go without.
Old Dec 13, 2012 | 03:08 PM
Beechkid's Avatar
Beechkid
Agreed!!!!!!
Old Dec 13, 2012 | 04:21 PM
thewestie's Avatar
thewestie
Thanks for the replies.
I have new heads and new manifolds that have machine marks on the flange surface.
Can I put them together dry that's how i did my first set
Old Jan 13, 2013 | 11:50 PM
thewestie's Avatar
thewestie
I put them on dry and have no evidence of a leak.
Old Jan 14, 2013 | 12:19 AM
Beanscoot's Avatar
Beanscoot
Great!
Uh oh my message has to be at least ten characters....
Justin Jones
Apr 17, 2019 07:40 PM
fromme87
Oct 24, 2015 05:21 PM
whiteyfordzx5
Nov 17, 2005 01:04 PM
muckypaws
1978 - 1996 Big Bronco
Sep 9, 2005 01:39 PM
brewster1
Exhaust Systems
Aug 22, 2002 07:30 PM
