back window
Old Dec 11, 2012 | 01:03 PM
haaaammmmmm's Avatar
haaaammmmmm
back window
Hello all, I have a 1988 f350, it has a solid back window, I was wondering if I could put a sliding back window in, if that would work how would I go about this? Any help/tips would be greatly appreciated, thanks a lot
Old Dec 11, 2012 | 01:19 PM
ewalt98's Avatar
ewalt98
I've read that you can use a window from any 80-96 F series with the only difference being the gasket and trim. If not, then surely the 87-96 would work.
Those windows are pretty easy to remove and replace using the rope trick.
Google "replace rear glass in truck" and you'll see some good examples.
Old Dec 11, 2012 | 01:24 PM
haaaammmmmm
Ok, thank you very much, its the same erra truck ie. 1987 to 1991, so let's hope for the best, thanks again
Old Dec 11, 2012 | 03:40 PM
deljac's Avatar
deljac
Its a real easy replacing them. Always easier with 2 people though
Old Dec 12, 2012 | 03:01 AM
TexasGuy001's Avatar
TexasGuy001
The factory slider has a different weather strip seal than the solid glass. The aftermarket slider uses the solid glass seal.
Old Dec 12, 2012 | 08:59 AM
Bansheesandrider's Avatar
Bansheesandrider
Actually the rear window is the same from 1973 to 1996(1997 on 250-350) and the aftermarket windows use the solid glass weatherstrip. The aftrmarket ones are better made than the factory one- the factory ones have prblems with the latch breaking and/or the frames coming apart.
FordOwnerJoey
Apr 3, 2013 11:24 AM
TOUGHLover
Paint & Bodywork
May 26, 2007 10:50 AM
Matt66
Oct 12, 2006 05:02 PM
llostll65
Mar 23, 2005 02:17 PM
nitro94
Dec 28, 2002 10:40 PM
