upgrading battery cables & starter cable
Old Dec 10, 2012 | 06:56 PM
big dirty's Avatar
big dirty
Along with replacing oil cooler, deleting egr cooler and upgrading other parts..
I have decided to replace all charging cables & starter cable.
I have enough 1/0 welding cable left over from my rock crawler build to replace everything.
I got the charging cables covered, but I am unsure what size cable to use from the passenger battery to the starter.
Also....... does it matter what connector I use at the starter end? I see that Ford used an end that doesn't allow the connector to spin while tightening the nut.........does it matter?
Thanks
Old Dec 10, 2012 | 07:23 PM
BLADE35's Avatar
BLADE35
It dont matter on the end Dave
Your Gona need a DC Power alternator to go with all this Upgraded Cables LOL
Do the grounds to if you have enough
Old Dec 10, 2012 | 08:03 PM
big dirty's Avatar
big dirty
I don't have enough form the grounds, but all it takes is for me to stop by Airgas welding supply on the way home and pick up some more.
I will do that after everything else is done.....
Been looking at the DC ALTs and I am considering it, but will have to wait till after Xmas.
Old Dec 10, 2012 | 08:10 PM
BLADE35's Avatar
BLADE35
Ya I would wait to since your alt isnt Dead x-Mas is a Hard time to do it for me to
Just be glad you can do your own wrenching dave I have seen a Handful of folks breakdown in the Last few weeks and have a mechanic/repair Bill that I would Consider straight up Theift
The Good thing about DC is they dont require a Core so you keep your old one for a Backup
These trucks take alot of Juice at startup
Old Dec 11, 2012 | 06:42 AM
big dirty's Avatar
big dirty
Yeah.......... I could tell that (start-up) takes a lot of juice just by seeing the thick cable from battery to starter.....geeesh
I got to take the new cables and have ends put on them one day this week. I think I am just going to do the charging cables for now and next payday do the rest.
Greenmillwork
1978 - 1996 Big Bronco
Feb 22, 2009 04:56 PM
pharic
Apr 11, 2007 02:00 PM
kirketime
1997 - 2003 F150
Apr 7, 2007 11:27 AM
mattmc
1997 - 2003 F150
Nov 22, 2006 11:42 PM
Arnold Kenyon
Electrical Systems/Wiring
Mar 3, 2005 07:31 PM
