1993 EX Positive battery cable length?
Old Apr 10, 2007 | 10:13 PM
pharic's Avatar
pharic
My fiance is having some problems with her 1993 Explorer. Basically it will start most of the times, but once in a while the relay will just click. I replaced the end on the positive battery cable (there was alot of corrosion), and that helped for a little bit, but the problem is back and more frequent. I went under the truck and noticed that the cable to the starter is also corroded and the sheething of the cable is also missing close to the terminal and the actual cable is exposed (green and corrodedand then some).
I would like to replace this cable, would anyone know what the length of it is? The one from the battery to the starter.
I'm going to pull the starter and replace the starter solenoid while I'm at it also.
Any help would be appreciated....
Pharic
Old Apr 11, 2007 | 12:23 PM
mikeinri's Avatar
mikeinri
Something like 72 inches. Buy the real one (from Ford or NAPA), not a WalMart special.
Mike
Old Apr 11, 2007 | 12:54 PM
aquanaut20's Avatar
aquanaut20
Its not an exact science, but you could use a tape measure to get an approximation.
Old Apr 11, 2007 | 02:00 PM
pharic's Avatar
pharic
Thanks for the replies!!!
I called NAPA and Part Source today, the length of the cable is 71" and has the pig tail that goes to the starter relay from the battery terminal. The cable cost me $13.99 CDN.
Thanks again,
Pharic
Gerritd1
22
Feb 6, 2012 09:13 AM
pwauburn
Dec 9, 2011 10:07 AM
busflyer
Electrical Systems/Wiring
Aug 16, 2011 01:43 AM
busflyer
May 2, 2011 02:35 PM
BEAVER
Jan 20, 2002 01:46 PM
