E4OD valve body torque settings
Old May 24, 2003 | 12:52 PM
upnorthsox's Avatar
upnorthsox
Help anyone! I'm installing a shift kit and I can't find the torque settings for the accumulator and valve body bolts, also the soleniod pack screws. I had them written down but can't find them now, I believe they're in in/lbs.
1992 F150 4x4
E4OD
5.8Lw
Transgo shift kit
Thanx in advance
Old May 24, 2003 | 02:30 PM
dieselzen's Avatar
dieselzen
Accumulator Body Bolts - 80 inch lbs.
(3) Center Support Bolts - 72 inch lbs.
All Valve Body, Solenoid, and Stiffener Plate Bolts - 100 inch lbs.
(3) Nuts for Valve Body Case Studs - 120 inch lbs.
Oil Pan Bolts - 12 ft. lbs.
Old May 24, 2003 | 02:52 PM
upnorthsox's Avatar
upnorthsox
Awesome! Thanks alot Dieselzen.
Old Dec 26, 2015 | 06:52 PM
Frank Pope's Avatar
Frank Pope
Do not tighten anything to 120 on this transmission I just broke my nut completely off by going with 120 torque pounds
Old Apr 14, 2023 | 11:23 AM
Genodat's Avatar
Genodat
4th Gear
info here
Id I'm at IL ig ip io im
Old Apr 14, 2023 | 11:41 AM
jk080's Avatar
jk080
Transmission Rebuilder
72 INCH pounds is equivalent to 6 FOOT pounds.
Over torqueing the center support bolts will deform the case not the valve body and that's not good either.
Old Apr 14, 2023 | 01:30 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What is 120 torque pounds? I've never heard of that.
120 inch pounds is correct. 120 foot pounds will break it right off.
Old Apr 14, 2023 | 03:04 PM
meborder's Avatar
meborder
Are there people tearing apart transmission that don’t know the difference between inch pounds and foot pounds!?!!
my goodness!!!
Dirtrider0213
Aug 12, 2009 10:27 PM
mudslingur
May 7, 2008 10:20 PM
TNT
Mar 8, 2008 01:19 PM
StinkyD
Jan 14, 2006 02:15 PM
matthews_56
Jul 10, 2003 06:43 PM
