Gas Gauge Problems
Old Dec 9, 2012 | 10:06 PM
jgavac's Avatar
jgavac
Gas Gauge Problems
I just recently picked up a 87 F250, and I'm having some issues with the gas gauge.
While driving down the road, the needle jumps around rapidly everywhere from empty to way past full. This happens with both tanks. I thought it might be the plug on the back of the gauge (Because it's the same between tanks), but the plug is clean and securely on the terminal. Any ideas of what could be causing this?
Thanks
Jameson
Old Dec 10, 2012 | 03:05 AM
Opossum's Avatar
Opossum
Mine had a similar problem, it got a lot better then I cleaned the terminals at the fuel selector solenoid on the frame. I switches the gauge signal between the tanks as it also switches tanks.
Old Dec 11, 2012 | 06:55 AM
Hutch17's Avatar
Hutch17
Where is the selector on the frame? I couldnt find mine for the life of me
Old Dec 11, 2012 | 08:09 AM
klricks's Avatar
klricks
Thanks
Jameson
What engine? Carb or EFI?
Are the temp and oil pressure gauges working and steady?
Old Dec 11, 2012 | 08:15 AM
mpgo4th's Avatar
mpgo4th
Ford used a slosh module in those years. Its a large computer chip looking piece on the back of the gauge cluster. Its job is to keep the needle from moving around during normal driving. Im not sure if your 87 truck has one but mine went bad on my 87 mustang.
Old Dec 11, 2012 | 08:21 AM
klricks's Avatar
klricks
Please state year, engine size. (Put in profile and/or make a signature).
The systems are vastly different depending on year, engine etc.
80's could have solenoid valve OR dual function reservoir (non electric) OR motorized electric valve. 90's + have no external selector and use check valves internal to the tank pumps.
Old Dec 11, 2012 | 09:57 AM
jgavac's Avatar
jgavac
Imfo should be in both garage and sig. 87 f250 6.9 idi dual tanks.
Engine temp gauge doesn't read at all, but the rest work fine.
Jameson
Old Dec 11, 2012 | 11:40 AM
Hutch17's Avatar
Hutch17
Well I have a 91 f250 with a 5.8
Old Dec 11, 2012 | 01:25 PM
Opossum's Avatar
Opossum
Hutch17 this is Jamesons' thread your truck has a very different system then his.
Jameson you should have the selector mounted on the inside of the driver frame rail about even with the front of the front tank. And yes it's a pain, you will be cursing Ford for not mounting it just a few inches further forward.
Sence your issue is with both tanks and they both do exactly the same thing your issue is very unlikely to be senders. Both senders go to this selector and are switched at the selector at the same time the tanks switch. I'd start by unplugging it and cleaning/checking the contacts. I'd be willing to bet that will do a lot of good. The location of that selector often cakes it with mud and road grime.
When your tanks get lower, take note on if the high point of the needle swings. You say it swings back and forth, but when you are full it does swing from full to empty but if you have say half a tank swing from half to empty? This is what mine would do.
Old Dec 11, 2012 | 01:57 PM
Hutch17's Avatar
Hutch17
Sorry, Since we have the same body style I figured it would be the same.
Old Dec 11, 2012 | 02:34 PM
klricks's Avatar
klricks
Jameson
These 3 gauges - Fuel, Temp, and Oil Pressure are all powered by the Instrument Voltage Regulator on the instrument cluster. If all 3 gauges don't work at the same time, then the IVR or it's wiring is suspect.
Old Dec 14, 2012 | 09:32 PM
jgavac's Avatar
jgavac
Wouldn't it be all four? Volt, fuel, temp, oil psi?
I pulled the plug off the switch (dang it's in a bad location...) and the terminals were in good shape, but I cleaned them anyway. The rear tank started reading at 1/4 tank, which I believed to be accurate. When I put 10 gallons of fuel in the rear yesterday, it started reading as full (up from 1/8 tank; did some driving). I can't imagine the tank is only 12-14 gallons...
The front tank is still reading funky. When I'm not moving, it reads waay past full, and when I'm driving, it moves between 3/4 and empty
Jameson
Old Dec 28, 2012 | 09:34 PM
toddpyles33's Avatar
toddpyles33
thts probably right for the rear tank. the gauge only reads about 14-15 gal of the 18 gal capacity. but my front tank is doing exactly what your picture showed. it went from flutuacting all the time to stuck past full. had several ppl tellin me to trace the wires down becuz the touching somewhere cutting the sending unit out of the circut and reading full tank 24/7. gonna look into it as soon as a get some garage space or it warms up. 15 degrees out now burrr
NM76F150
26
Jul 23, 2017 11:42 AM
little dutch
Dec 14, 2012 01:53 PM
mcne
Mar 20, 2007 08:37 PM
JBronco
1978 - 1996 Big Bronco
Apr 23, 2005 07:38 PM
f-4x4
Oct 20, 2004 01:30 AM
