transmission????
Old Dec 9, 2012 | 05:32 PM
Scott Moore's Avatar
Scott Moore
transmission????
i have a 95 f150 with a 5.0 liter/automatic trans with overdrive. will run fine till it warms up a little bit then when you take off the engine bogs down almost like if you were trying to go up hill in high gear, then it will take hold and go till you come to a stop again. im at a lost on this never had anything act like this.
Old Dec 9, 2012 | 05:48 PM
Conanski's Avatar
Conanski
This could be powertrain related or it could be something mechanical, pull the codes and check fuel pressure, and if all that comes back clear then start looking for things like dragging brakes.
Old Dec 9, 2012 | 05:51 PM
Scott Moore
there are no codes brakes are free and if you take it out of gear the engine will run just fine ,just happens after it warms up and you take of it will bog down and barely move
Old Dec 9, 2012 | 07:27 PM
rla2005's Avatar
rla2005
In your other thread you said your reader would not connect to the PCM? https://www.ford-trucks.com/forums/1...l#post12577238
Old Dec 9, 2012 | 08:21 PM
bakos's Avatar
bakos
Are you saying the engine bogs down - cant get rpms up? Like a fast WOT is just fine?
So when your trying to get going you can put in in neutral and it will rev it up and it runs fine?
When you get it rolling and its acting up see what neutral does. All sound more like your motors cutting out under load
Fuel - then - spark
Old Dec 9, 2012 | 08:24 PM
Scott Moore
when its acting up and you put it in neutral it runs fine
yes scanner wont communicate with computer show no codes useing the flash method
Old Dec 9, 2012 | 08:29 PM
bakos's Avatar
bakos
A quick wot ?
Old Dec 9, 2012 | 08:31 PM
Scott Moore
a quick wot????
explain please?
Old Dec 9, 2012 | 08:42 PM
bakos's Avatar
bakos
Pedal to the floor - wide open throttle
Old Dec 9, 2012 | 08:45 PM
Scott Moore
crap i knew that ....in neutral runs as should in drive engine is bogged down at any throttle position for 30 sec to a min. then it takes hold and runs good till you come to a stop again
Old Dec 9, 2012 | 08:51 PM
bakos's Avatar
bakos
Got gas in her - rite
Assuming you have fuel and pressure. I'd be checking spark - dis cap, plugs wires
For the lark of it look the motor all over while running in the dark
Old Dec 9, 2012 | 08:57 PM
Scott Moore
done an engine swap for a different issue and it had this problem before the engine swap
Old Dec 9, 2012 | 09:09 PM
Scott Moore
although i did replace the ignition module and it seemed to get better
Old Dec 9, 2012 | 09:19 PM
bakos's Avatar
bakos
Wow - that kinda puts a new spin on it. Did you ever check for sparks in the dark
Old Dec 9, 2012 | 09:20 PM
Scott Moore
yes no jumping fire as far as i could see
