transmission????
Old Dec 9, 2012 | 09:30 PM
Scott Moore's Avatar
Scott Moore
also took engine out of a wrecked truck i just unplugged the main engine harness and left everything on the donor engine....so the problem has not moved with the engine swap....
Old Dec 9, 2012 | 09:48 PM
Scott Moore
i replace the engine with one out of a wrecked truck ... i just unplugged the main engine harness and left everything on the engine..nothing was used from the old engine
Old Dec 10, 2012 | 12:08 AM
Xclimation's Avatar
Xclimation
Check vacuum lines. I had a similar situation in a Ford Fairmont and it was a tiny pebble in one of the vacuum lines blocking it.
Old Dec 10, 2012 | 07:52 AM
bashby's Avatar
bashby
Sounds to me like it won't downshift after it warms up. Have you tried pulling the shifter down to 1st?
Old Dec 10, 2012 | 09:39 AM
Scott Moore
yes it don't matter what gear you have the selector lever in it acts just the same although i haven't noticed it acting up in reverse.. that's not to say it don't i just haven't noticed it
Old Dec 10, 2012 | 09:52 AM
Conanski's Avatar
Conanski
Originally Posted by Scott Moore
yes scanner wont communicate with computer show no codes useing the flash method
Meaning the light doesn't flash at all?
done an engine swap for a different issue and it had this problem before the engine swap
That pretty much confirms it then you got a computer problem.
Old Dec 10, 2012 | 09:54 AM
Scott Moore
changed the computer out as well when i changed the engine out
Old Dec 10, 2012 | 10:03 AM
Scott Moore
like i said im at alost the only thing i can think of is it being the transmission
Old Dec 10, 2012 | 10:31 AM
bakos's Avatar
bakos
sounds like bashby is onto something.
is the truck taking off in 3rd gear or 2nd
Old Dec 10, 2012 | 10:35 AM
Scott Moore
it kinda acts like your brake torquing it if that makes any sense and no the brakes arent sticking...and when it does take off its in first
Old Dec 10, 2012 | 12:37 PM
bakos's Avatar
bakos
how do you know its in 1st for sure, from your discription it sounds like its taking off in 2nd. Check linkage from colum to trans. ?
mystery - so when you get going you can shift from 1st through all the gears? what speed and rpms can you get taking of in 1st
Old Dec 10, 2012 | 07:54 PM
Scott Moore
well truth be know i dont really know but i do know once it does go it shifts through all gears and you can put it in 1st and it will do the same thing.......now what are the possibility that a wiring problem could be causeing it because the computer wont communicate with my scanner even after changing the computer so that points me to maybe a broken wire between the pcm and the eec connector or at least thats my thinking anyway
Old Dec 10, 2012 | 08:25 PM
  #28
HrdDrv's Avatar
HrdDrv
Just a question,
What's your timing set at? Is it pingin under load?
Old Dec 10, 2012 | 09:16 PM
  #29
Scott Moore
Originally Posted by HrdDrv
Just a question,
10 degrees and no pinging the only thing it does when acting up is pop through intake
Old Dec 10, 2012 | 09:18 PM
  #30
Scott Moore
slightly not bad at all not enough to cause concern if that even makes sense
