a/c compressor
Old Dec 9, 2012 | 05:26 PM
Cattle Rancher 82's Avatar
Cattle Rancher 82
a/c compressor
is the triangular shape thing with the 3 ***** on the pulley supposed to turn all the time when truck is running? 97 ford f250 5.8
plus had alternator rebuilt, new brushes, bearings, and rotor. still has the battery light coming on and gauge showing low
Old Dec 9, 2012 | 05:31 PM
blkF250HD's Avatar
blkF250HD
It's supposed to cycle on and off with the A/C on. You may have a low charge if it's spinning continuously. Turn the A/C off and see if it stops turning. If not, then the clutch is seized and not disengaging. Time for a new clutch or compressor at that point.
Old Dec 9, 2012 | 05:38 PM
Cattle Rancher 82
ok thanks! it doesn't turn all the time, it kicks in and out with the a/c on and off. just wondering because i've heard belt squealing seems to be coming from that point
Old Dec 9, 2012 | 06:13 PM
Encho's Avatar
Encho
The Southernmost Mod
You might be needing a new belt. When the A/C compressor kicks in it creates an extra load, the squeaking could come from that.
Old Dec 9, 2012 | 06:28 PM
Cattle Rancher 82
the belt has been on there about 5 years now, burnt the old one off when the smog pump locked up
Old Dec 9, 2012 | 06:29 PM
Cattle Rancher 82
also could the belt be making the battery light and gauge to go low? I had the alternator rebuilt..
Old Dec 10, 2012 | 04:44 PM
blkF250HD's Avatar
blkF250HD
If the belt is slipping then yes. How old is the tensioner?
Old Dec 10, 2012 | 04:54 PM
Cattle Rancher 82
i dont think the belt is slipping. the tensioner is 5 years old also, i replaced smog pump, belt, idler pulley and tensioner all at the same time. i have to replace the idler pulley again, darn plastic one is about worn out already..
Old Dec 10, 2012 | 06:57 PM
Encho's Avatar
Encho
Replace the belt, and get a steel idler pulley, I did and haven't had a problem with it ever since.
Old Dec 10, 2012 | 09:30 PM
Cattle Rancher 82
planning on it...any tips on brand of belt from advance, auto zone or napa?
Old Dec 10, 2012 | 09:59 PM
Encho's Avatar
Encho
The Goodyear Gatorback belt is an amazing product, I would get either that or a Bando, which is pretty good too.
Old Dec 11, 2012 | 08:05 AM
busch6062's Avatar
busch6062
I second what Encho said. The Gatorback is awesome.
Old Dec 11, 2012 | 11:43 AM
Cattle Rancher 82
what about Dayco W profile rib belt?
Old Dec 11, 2012 | 08:02 PM
Encho's Avatar
Encho
No idea, I've just had my Gatorback for quite a while now and it still works amazingly well.
Old Dec 11, 2012 | 09:50 PM
Cattle Rancher 82
I like the name Gatorback...I seen the Dayco belt on auto zones website, and watched a video on the belt, its a new belt Dayco designed. It looked like a good belt. They also have a no slack idler pulley i'm thinking about getting, its made out steel. The good thing is they say Dayco is made in the USA
