About the tailgate key switch part number
good info..thanks..I'm fairly handy about harness repairs and adapting one from a later year would be ok actually. I'm surprised Ford didn't make a replacement universal one to be spliced in..but I guess we shall see...and of course..should probably make sure the local salvage yards aren't crunching any Broncos at this time..
You could try testing the wires, from the plug behind the taillight to inside the tailgate too. They are known to break in the area where they bend as the gate opens & closes. It's also common for the contacts inside the dash switch to get hot & corrode/burn, causing the tailgate window circuit to lose the ground connections. There is one for up, & one for down so that may cause the window to only go one way, usually both seem to go at the same time.
Hmm, would it be possible to open the switch body itself and view the board? Maybe you can get to the bottom of the button and clean the gunk out that is preventing the connection. Shoot i should do that with my own switch since it doesn't work period, though the only way i know to test them is to wire them up each time which could be troublesome. Then again i don't know much about this switch so it is probably easier than that. The point is do you HAVE to replace the whole thing or could you fix the current one? Seeing as they are hard to come by i would imagine people have done this before.
The whole switch assembly is a molded unit, including wires. I doubt there would be any way to cut or break it apart without destroying it beyond being usable. There is a ton of info about the tailgate wiring & diagrams available on fullsizebronco.com. Search on there for info. You should find a clear wiring diagram, along with pics of the switches and actuator.
good input...
This is a good conversation..evidently one that is relevant to more than just myself at least.
In my case, with this 86, I really don't want to take it all apart w/o the parts I want to have on hand for a proper long-time fix. I have another dash switch coming so as to have on of "those" on hand.
My wiring is fine..but that pesky DOWN micro-switch on the rear..Oh well..the race is on for a NOS piece that I can use for a repair...
I have been to the "pik'n'pull often" just don't really want to "pick,pull,and install" another 25+year old switch...that's my story...
"an' I'm stickin' 2-it"
Haha don't worry we know what you mean. The problem is I just don't think anyone fixes them or restores them. I also have never heard of anyone making new ones either. you might get lucky and find an unused one that was in some warehouse that a ford shop used but that's a slim chance I think. I guess if you find something the let us know so we can all jump on it too
#29
on
My key switch thing is clear gone. Just the key tumbler that works but no switch. I do wish I had even the old one so I could use it to make something that would work. Climbing my crippled **** in and out of the truck with the custom ball buster seats is a real pain. Literally. I am sure (like Dylan) that if I applied myself and put my mind to it I could come up with something that would work as well if not better than what Henry had in there. I guess I should get some kind of manual with a pic of what was there to start with.
Hey, I wonder if the Bronco Graveyard Catalog has a pic of it. I need to find it and look I guess.
#30
it even has info on the switch but not how to fix.
