Turbo Silencer Ring?
Old Dec 9, 2012 | 02:28 PM
HunerdProof1371's Avatar
HunerdProof1371
I was hunting with my buddy who has an 09 Cummins and he was tellin me about removing the silencer ring on his turbo and said I should do the same. Does the 6.0 have this part and if so what can I realistically gain from removing it?
Old Dec 9, 2012 | 02:37 PM
MisterCMK's Avatar
MisterCMK
There is no silencer ring to remove.
Old Dec 9, 2012 | 02:38 PM
Lilpooh's Avatar
Lilpooh
The 03 turbo has a removable ring that can be pryed out, the 04-07 turbo ring has to be machined out. The only gain will be a slight increase in whistle coming from the compressor wheel, IMO really not worth the hassle. The 03 turbo gets the loud whistle from the turbine (exhaust) side, remove the kitty and muffler, then you'll have more whistle than the Cumapart.
Old Dec 9, 2012 | 02:43 PM
Lilpooh's Avatar
Lilpooh
If your feeling the urge, here ya go.
Silencer Ring ? - Ford Powerstroke Diesel Forum
Old Dec 9, 2012 | 03:22 PM
Maxium4x4's Avatar
Maxium4x4
I agree with Lilpooh, not worth the effort. 03 will pry out as stated.
Old Dec 9, 2012 | 05:18 PM
HunerdProof1371
Gotcha, ok my buddy made it sound like it might make the turbo work better. If it just makes it louder I might just do it when I start doing an EGR delete.
Old Dec 9, 2012 | 05:48 PM
Maxium4x4's Avatar
Maxium4x4
What is wrong with the turbo?
Old Dec 9, 2012 | 06:30 PM
HunerdProof1371
It lags quite a bit, if I floor it at a stoplight I'm at 15mph before it kicks in.
Old Dec 9, 2012 | 06:35 PM
Maxium4x4's Avatar
Maxium4x4
You have other things going on then, dirty unison ring perhaps, leaking charge air boot. Time to crawl under the hood and have a look around. Visit the Tech folder at the top of this forum.
Old Dec 9, 2012 | 06:47 PM
HunerdProof1371
Wonderful...
Thanks y'all!
Old Dec 9, 2012 | 07:07 PM
HunerdProof1371
I can say with a fair degree of certainty that my turbo hasn't been pulled and cleaned in the 145k miles it has on it. Would doing this help?
Old Dec 9, 2012 | 07:16 PM
Yahiko's Avatar
Yahiko
Yes
Sean
Old Dec 9, 2012 | 07:19 PM
Maxium4x4's Avatar
Maxium4x4
It would be fair to say your turbo needs a little attention.
Old Dec 9, 2012 | 07:49 PM
HunerdProof1371
Good to go, looking up videos on how to get that done now. For someone who's never messed with a turbo before how long should it take to remove the turbo, clean it, and get my truck back up and running?
Edit* - Also, I will be using hand tools only, a 3m pad and some CLP gun cleaner
Old Dec 9, 2012 | 08:29 PM
Maxium4x4's Avatar
Maxium4x4
Hahahahahha... well let me say this, it will go better the next time. That one bolt (03 exclusive) behind the turbo is a pita until you do it once. Do read plenty and a few tools help. Swivel flex heads are nice.
Turbo down pipe helpful tip of the day: Once you loosen the bolt, the clamp stays tight, crawl under the truck and kick the sucker.
