I did that for a couple years because I hardly drove the van. 86 van. At the end I plugged it in and it started much faster. I ended up changing IP, injectors and glow plugs and return lines. Light stays on and starts great. Of corase now I have a cooler leak. Figure,
just go buy you a can of ether and three lil squirts gets it done, and for manual glow plugs put a switch or a button in. disconnect the white wire from the g pug relay and run a new wire from the g pug relay into the cab. connect that wire to the switch or button, then the other post of the switch run a ground wire to it just ground it in the cab or somwhere like that. also check for air intrusion injectors and rings on em, and the fuel selector valve in between the tanks. if it is the lift pump post back and i will tell you how to wire in a electric pump.
It should start faster than that. My gp harness is shot, and one glow plug is missing the top of it. Anyway you shouldn't have a problem like that starting even when cold. Just a little extra cranking and smokey and loud once it starts.
I had fuel system issues a while back and it starts much faster this winter, with crappy plugs then it did last winter.
