Hi all, i have an 08 that the heater either works all hot or cold. It seems that when i try to control the temp it isnt consistent. It will be on hot,**** turned all the way the right in the red. Great, it gets too warm in the truck so turn it down a little. Then it is too cold. I only turned it down a little, not even in the blue zone yet. I turn it up alittle and it is still cold. Turn it all the way up and it is too hot again. What is up with this. I hope it isnt the blend door syndrome. The truck only has 30,000 on it. Thanks
I have this problem on my 08. I have just dealt with it because I expected it to cost more. Now that I know it only about $20 I will get this job done.
Ok all done. I started at 7:30 and 1 hour later it is fixed and put back together.the job is relatively easy but a little frustrating due to the confined area to work. If you have a short 8mm gear wrench I recommend bringing that to remove the 3 bolts securing the actuator. I used a regular short wrench and it went ok. It is really a straight forward parts change and the video was spot on (minus the anti Ford chatter) I wish I did this last winter when it started.
