AD or AE?
Old Dec 8, 2012 | 02:25 PM
Hawk180's Avatar
Hawk180
AD or AE?
I recently got a SES light on my truck. I hooked up my AE and run the checks on it. The first DTC list came back with the throttle position sensor B circuit fault. I'll replace that this weekend. In doing a cylinder contribution test, I got a #8 cylinder circuit balance fault. I shot the wires all the way back to the IDM with no faults. I have a Riff Raff Frx on the truck and I was wondering. With the fuel return system, would it be OK to replace the AE injector with a AD? Or would I need to go with Snowseeker's fuel rail reverse mod in order to do that?
Old Dec 8, 2012 | 02:34 PM
Bonanza35's Avatar
Bonanza35
The CPS always gives you a code for #8, so do you have a problem or just want to change the injector. There's know reason you can't switch to the AD injector if you want, but I don't see any advantage.
Old Dec 8, 2012 | 02:45 PM
Hawk180's Avatar
Hawk180
That's great. So I'll just change the TPS and clear the codes. Should be good to go.
kper05
6.7L Power Stroke Diesel
16
Mar 16, 2018 09:33 PM
SNOWR8R
Oct 6, 2017 12:12 AM
hawkco66
Apr 26, 2017 07:18 AM
RKCORPS25
Nov 1, 2013 09:34 AM
MAKO314
Apr 13, 2007 09:18 PM
