Can I time this without a pointer?
Old Dec 6, 2012 | 09:10 PM
topfuel's Avatar
topfuel
Hey Guys, Help me out, I put together a 89 mustang 5.0 engine together and went old school on it. I put a flat tappet lumpy bump stick in place of the roller cam and went with the good old holly 4bbl. I started with a stripped long block so I used all my 1969 302 parts. anyway, I dropped in the dist and because of the high rise intake I can only advance or retard about an inch back and fourth, Also I have no pointer on my timing cover, I got #1 up on comp stroke matched it to #1 on the cap and vroooom she fires right up, the ol gal is running a little hot, and I dont know how to time it with my intake hitting and no marks down below, Also can I take off the vac advance? it would let me turn the dist more.....Help. Thanks guys
Old Dec 6, 2012 | 09:52 PM
P38fighter's Avatar
P38fighter
You say you have no pointer but are the timing marks still on the balancer? If not you can get timing tape from many hot rod suppliers ...
Old Dec 6, 2012 | 10:01 PM
jacks61ford's Avatar
jacks61ford
use a vacuum gauge to time it it should get u close imdidnthat same as you only went with a lumpy roller
Old Dec 6, 2012 | 10:04 PM
tinman52's Avatar
tinman52
Welder User
You can time it with a vacuum gauge.....advance to the highest vacuum reading then back it off a little. If it pings, back it off more. It will run without the advance can, but not nearly as well at idle and off idle...
Old Dec 6, 2012 | 10:05 PM
Boss9F100's Avatar
Boss9F100
Find TDC and make your own pointer. Make a stopper for piston near TDC mark where its at, rotate opposite direction until it stops again and mark. ZERO will be half way in between.
Curious if you have std or reverse rotation water pump and also pulley setup? Common thing for overheating is turning waterpump opposite direction of what it was intended for.
Looking for trouble not knowing where your timing is at.
Sounds like your dist is off one tooth. Just move it the one tooth so you can get proper advance.
rsh1966
Jul 23, 2019 08:08 AM
Scott Yager
36
Jul 21, 2017 09:34 AM
jimbo beam
Nov 20, 2013 10:31 PM
jaye
Apr 24, 2009 07:28 PM
mike460
Feb 6, 2002 05:55 PM
