Hello, i have been reading some threads for the past couple months on research and comparing my truck to others. I have a 1985 F150 with a 300ci i6 and i am wondering if there is a way to identify the engine due to the fact that it is not original. The first owner, i am the third, put a brand new engine and transmission in the truck. And i am curious as to what year the engine is. Any advice/help is appreciated!
Also, as an aside, is all of your feedback equipment still present? If there are no emissions inspections in your area and you have missing emissions equipment, it's imperative that you swap to DSII so that your motor has working distributor and the fuel mixture can be set.
Where are the casting numbers located? unfortunately the stick has faded. By appearance i would say it looks more like the 65-83, the thing is though the motor was brand new when it was put in, there is currently 33,xxx miles on the engine. I will post pictures this weekend and maybe you could help, there are some lose ends with the engine with vacuum hoses not hooked up or hoses missing completely
Forgive me for this is my first vehicle and i am trying to learn as much as i can so i don't appear to be a complete idiot, but i am not sure what you mean by feedback equipment. There is no emissions inspection for my truck and i do believe that i am missing emissions equipment. I know the o2 sensor is not attached because the local ford dealer said the air filter housing had vacuum hoses not attached and the hot air box(?) is missing along with the hose so it was non functional.
Reason: disable smilies
Stock 84 to 86 F-series trucks came with what is known as a "Feedback Carburetor." It's a computer controlled carburetor that Ford Motor Company implemented on the inline 6's, 302's, and 351's that allowed Ford to pass emissions requirements before the transition to EFI was complete.
If all of the emissions equipment is there and properly functioning, it's a great setup (albeit complicated). However, if there's any emissions equipment missing, the computer will throw a code and lock your ignition timing so that it won't advance, and the fuel mixture gets rich and locked as well. This is a function so you can get your vehicle home. Here, it's referred to as "limp-home mode".
Dating is done by finding the casting #'s on the block. They're on the passenger side of the block on a 300.
Take a photo of your motor from various angles just as it sits right now and I'll be able to give you a general year range that the motor came from (provided the lifter cover and valve cover are original). I'll also be able to tell you whether or not it's worth it to keep the feedback carburetor you have or swap to DSII. We have a resident feedback expert here that can help you with your feedback system if it looks like it can be easily fixed. If not...
Remember that a Casting ID will only tell you when the part was designed for use, not when any particular discrete component was actually manufactured.
If it is in "limp-in mode" it will have no power and get worse fuel mileage than a 460. As for identification, there will also be a date cast into the block, it will usually be up to a year older than the truck build date.
The hazard of running an engine in limp mode is possible overheating, and maybe ruining your catalytic converter.
A properly tuned 300 can normally get upwards of 17 MPG, so its probably not running optimally. There are tons of things that can cause poor mileage, especially from a feedback carb equipped vehicle.
I may be wrong, but a way to tell if it is limp home mode is to check the timing with a timing light, if it is not advancing when the throttle is pushed open, then it is in limp home mode. (be careful of the fan!)
okay, i don't believe it is in limp in mode because it runs fine and doesn't overheat, the gas mileage is as expected (11 mpg).
11 MPG? It's in limp home mode alright.
The O2 sensor being unplugged will cause that, among others things.
A DS-II conversion would be a good course of action in the future.
A good running 300-6, depending on gearing, and how you drive it, should get you between 15 and 20 MPG easy. The average is around 18.
Originally Posted by ctubutis
Oh, you'll certainly know when it's in limp mode; when my car gets into that state, it won't go more than 30 MPH.
The 300-6 is a little more tollerant. It will seem to run fine when not working properly, and for people who don't know that it's supposed to run better etc. I've seen people assume because it's a six cylinder that it's underpowered and slow. It's usually due to issues that need to be fixed, preconceptions that it's only a six, and trying to wind them out like a V8 that are the real issues.
I'm willing to believe when the owner does a DS-II conversion, and when the fuel mileage increases, and the performance increases by at least 1/3 that he'll have a, "Who Knew!?" moment.
My truck can easily reach 45/50 mph but can't maintain higher speeds up even the slightest hills. It does sound like it is in limp mode from what is described. I have the pictures of my engine, how do i upload them?
