Cab Interchange. . .
Old May 23, 2003 | 11:00 PM
jaimalade's Avatar
jaimalade
Hello All,
Once everything (both exterior and interior) is removed from an '84 F-Series cab, how different is it from an '88's? What I am asking is: Can I swap eveything (concerning the cab) from my '88 F-250 to a totally stripped '84 cab? I want to know EVERY little difference between the two, if there is any. . . Thank you all very much for your time.
Respectfully,
Nathan
Old Jun 15, 2003 | 08:01 PM
hatcatz's Avatar
hatcatz
i dont think there is a diff
Old Jul 2, 2003 | 04:13 PM
Ed Bamba's Avatar
Ed Bamba
Not sure if there is a difference either. You may want to compare the firewalls though if you will be using the dash assembly from the 88 into the 84. Not sure when Ford switched to the hydraulicly actuated clutch from the mechanically (rods) actuated clutch setup; it may or may not be a factor also. The more experienced here will certianly correct my possible erronious input to this thread.
Nate1954
New Member Introductions
Aug 12, 2014 01:23 PM
royzell
18
Feb 21, 2008 02:01 PM
jaimalade
Jun 28, 2003 01:05 AM
jaimalade
May 26, 2003 12:06 AM
Nathan
Feb 18, 2000 07:19 PM
