moving engine perches
Old Dec 5, 2012 | 08:17 PM
68cabby's Avatar
68cabby
Ok..since I'm sooo close to dropping in the engine..I gotta move my perches forward a slot. I was cutting the old perch bolts out with a cutter wheel..before it shattered...I plan on doin the rest this weekend. Anybody got any good tips to get the bolt out that's under the manual steering box? How hard is it to rebolt? Or should I line the holes up and just weld em in?
Old Dec 5, 2012 | 10:38 PM
orich's Avatar
orich
I must have missed something of an earlier post of yours. Why are you moving the mounts perches ??orich
Old Dec 6, 2012 | 01:22 AM
RichS2659's Avatar
RichS2659
Probably going from a six to an FE, is that right? Sixes and FE's use the same perches, just slide them to the next bolt hole.
Old Dec 6, 2012 | 07:02 AM
jim collins's Avatar
jim collins
Can you just unbolt the steering gear and lift it up enough to get to the bolt. I would not weld it in, as often as i change engines around in my trucks , i would want it so i could move it again i the future.
Old Dec 6, 2012 | 07:58 AM
68cabby's Avatar
68cabby
Yes..I'm going from a 360 to a 300 that I rebuilt. New cam..intake..lifters..springs..timing gears..dual exhaust..etc. my friend had one that they pulled from his 70 so I got a good deal on the engine. Anyhoo..so I need to move them forward.
Old Dec 6, 2012 | 09:57 AM
willowbilly3's Avatar
willowbilly3
I've had some of the holes line up when I went the other way, six to FE. I see no problem welding them in. Welds can be un-done too if need be later on.
Old Dec 6, 2012 | 11:02 AM
68cabby's Avatar
68cabby
I was considering welding..ill just look where the holes are..bus they're kind of a pain to get to them from the underside
vemax
Jul 21, 2017 06:54 AM
greenmachine86
Sep 16, 2016 09:25 PM
1985tullyhowell
38
Oct 16, 2013 12:32 AM
piperig78
Jun 7, 2013 04:58 PM
kc0stp
May 14, 2013 04:11 PM
