how rare?
Old Dec 3, 2012 | 08:38 PM
68cabby's Avatar
68cabby
how rare?
Seen a couple posts about the factory bedrails. How rare are they? I have a 68 and like the look of them. I'm bidding on some..but definitely don't wanna overpay..what do you guys think?
Old Dec 3, 2012 | 11:55 PM
72Truckin's Avatar
72Truckin
I haven't really researched the bed rails. They do look good on some trucks.... not the look I'm going for, so, I'm not much help on pricing for these...
Old Dec 4, 2012 | 04:26 AM
jowilker's Avatar
jowilker
Mr. Wilson will know, don't think Ford offered bed rails, but could be corrected.
John
Old Dec 4, 2012 | 05:20 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Dealer installed accessory also available at the parts counter, introduced in 1970 8' Stylesides, retrofitted to previous years.
The same 8' bedrails were used thru 1991. The same 6 1/2' bedrails were intro'd in 1973, retrofitted to previous years and used thru 1991.
While many FTE members love them, I never cared for them. Limits reaching into the bed, unless you have ape arms. Have to remove them to install a camper shell, or use the stake pockets.
Mr. Wilker, Ford offered so many accessories back then, it would boggle your mind. Ever see a: vacuum ash tray, or a cigarette lighter/map light combination?
A "convertible" top with portholes for 1966 F100/250 Stylesides? Or bed steps for 1961/66 Stylesides...and Econoline pickups?
Old Dec 4, 2012 | 08:06 AM
Freightrain's Avatar
Freightrain
Back when you could order a truck JUST LIKE YOU WANTED IT. Not how the factory wants to build it (like today).
Old Dec 4, 2012 | 11:19 AM
1972RedNeck's Avatar
1972RedNeck
What was a vacuum ash tray?
Old Dec 4, 2012 | 11:24 AM
NumberDummy
Round glass bottle with a metal lid on it that had an ashtray that slid out. Flick your ashes/cigs into it, were sucked into the bottle.
Old Dec 4, 2012 | 02:45 PM
acreature's Avatar
acreature
Holy Buckets, expensive!
Old Dec 4, 2012 | 05:10 PM
jowilker's Avatar
jowilker
Well Mr. Dummy did they have the Ford logo on them?
John
Old Dec 4, 2012 | 11:13 PM
khadma's Avatar
khadma
Carpenter Local 745
Was this option cheaper than powered windows?
Rolling down a window could not have been to difficult back then
Old Dec 6, 2012 | 09:16 AM
1970explorer's Avatar
1970explorer
My 1970 F100 with Explorer package came with bed rails that screwed into the top of the bed. I believe these rails were used from 70-72. I found a set last summer and quickly purchased them. This is the only set I have ever found for sale.
I have also used the rails from 73 and beyond on my trucks. These rails can be modified to work with the bumpsides and fit in bed pockets which is nice (no screw damage to the truck). These rails are also getting harder to find in nice condition but I run across them more frequently.
Old Dec 6, 2012 | 11:10 AM
xlt70black's Avatar
xlt70black
Bed Rails
Like 70 Explorer said the 70-72's you had to drill like 10 holes on each side to mount them it still gave you the option to use the front and rear stake holes the 73 up models you took the center perch off and you moved it just a few inches to ceter it over the hole or you could cut off the line up pins and just let it float but then they are only good for looks you could not tie off to them they would give. Both models though had the adjustable tie points had a nut type retainer you just loosened with your fingers and it slid back or fourth these were plastic and aluminum so they were only good for light loades or tying down a tarp. Both models came with molded plastic gaskets to protect the finish
Matt300ZXT
Nov 19, 2008 10:54 PM
Yogi-96blazer
29
Mar 4, 2006 07:41 PM
JohnT
22
May 19, 2004 12:38 PM
fmt12ton
Apr 7, 2004 05:20 AM
cobraguy
Oct 22, 2001 02:25 PM
