My 2003 eats altenators. If my batteries are low on juice, I get the same symtoms you are.
This may not be your head unit problem at all. check your batteries for 13.7 volts while your truck is running.
Thanks. I will check my alternator also. It is a new rebuilt one. It does display between 13.8 and 14.1 while it's running. 11.9 before I start it. Now the radio is doing it when it's parked and key on not running. I'm trying to swap a friends radio from his excursion on Sunday or Monday. Just to check it out. This is driving me crazy!
I will disconnect that harness from the back of the radio tomorrow. That's a great way to check. Thanks William_04_x! I'm checking out the you tube link as well. I hope that something works. Also something I should share with everybody. I work two jobs right now. So time for me is limited. I will do my best to keep you all updated. Thanks again!
I had the exact same thing go wrong with my '04 X radio. I bought the steering wheel and console radio control modules. I replaced the console radio control module and that fixed the problem.
DSMMH
The oem head unit in my '05 Excursion just out of the blue started acting up. The volume will turn down all by itself. I turn it up, it turns back down. Sometimes it will take a few minutes before turning down.
At this point, I think I'd like to fix this and retain the oem head unit. Any more experiences/fixes with this issue? I haven't pulled the head unit yet, but when I do, I'm hoping I'll find a harness that contains the wires for the steering wheel controls and the back of the center console controls. Disconnecting these 2 control modules should eliminate them as the problem. Can someone confirm this test procedure?
Assuming the problem is with the head unit itself, has anyone had one repaired? Experience? Cost?
Thanks! I need to resolve this cost effectively before an upcoming road trip in May.
The rear speakers are routed through the rear control panel. bypassing the rear panel in the console will lose the circuit. Just to test the volume issue, the rear cup holders in the console just pop out. Temporarily disconnect that panel and see if the issue goes away. If it does, you know the panel is most likely bad. If it persists then it is in the HU or the steering wheel. If you then pull the HU and disconnect the smaller of the two connectors, square one I think and it still does it, then you know it's in the HU.
Hope this helps some.
This will get me going in the right direction. Thank You. I'll play with it tonight and report back.
Today my steering wheel was toasty from
all the sun. When i pushed to lower the volume
with the steering wheel control radio would
Go higher. I used the dial to adjust.
Later it worked fine.
Seems like the clockspring or switches?
Thankfully this happens only about twice a year,,,
The radio buttons work with ohms, through a single wire for all the buttons. The heat on your wheel/buttons warmed up the wires a lot (since the wheel/buttons are black in your case), and reduced the resistance in the wires. I don't have the exact numbers handy (they are written down in the book for that Excursion), but pressing each button on the wheel causes a different ohm reading on the one wire. In my case, using a different size wire or shotty temporary connector to connect to the radio caused the end ohm reading to be different because those added factors added more/reduced resistance. When I initially hooked it up, volume up did seek, volume down worked right, seek one way changed between AM/FM, etc. They were just all messed up. Once I got a good wire in there and soldered it into the harness on both ends, it worked fine.
Still though, I remember a couple times in the dead of winter that the buttons didn't work. I guess there was just too much resistance in the non-factory wires that it was just off enough for the radio to not know what to do.
So if your buttons don't work once in a really great while, I wouldn't worry much about it.
I meant to report back with my experience and solution on this....
In March my stereo volume all of a suddend started dropping to zero all by itself. From information in this thread, I was prepared I may have to replace the volume control buttons at the back of the center console or on the steering wheel. The back of the console being the much easier solution, I decided to take a preliminary look....
I popped out the cup holders and saw how easy this would be to replace. While I was there, I unplugged the wire harness from the volume control and plugged it back in.
5 months later, and the problem has not come back. I attribuite it to unplugging and plugging the harness back in. As described earlier, the controls work by the resistance over the wires; perhaps I had some stray ohms, build-up on the spade connectors, don't really know??
If the problem returns, the first thing I will do is remove that plug again and pack it with di-electric grease.
