My egnine is an oil burner, it runs great though, other than the oil it runs like a champ. so my question to all the gurus is how i should go about refurbishing my engine, im not interested in getting new rods/pistons heads all of that, im simply wanting to put all new gaskets all around, re ringing it the whole nine yards, about how much do you think a shop would charge to do this, or in turn do you think its something i could do with a little bit of knowledge about engines, over a two week period, thanks for all of the help in advance, by the way engine is 1973 429
Do you know why it is burning oil? Have you done a compression test? What about a leakdown test?.. ya need to perform a diagnosis there doctor.
It could be as easy (a relative term) as having the heads rebuilt or re-ringing it. The latter is typically referred to as an "overhaul" rather than a rebuild.
A well planned overhaul, barring unforeseen broken bolts/studs or parts availability or block condition, could be done over a week. Depends how well the machine shop responds too.
BUT, ya never know what needs to be done until it is take apart, measured, and understood what a machine shop charges for certain work. Prices vary widely as does the quality of the work.
hmmm idk what those tests are, what i do know is that the engine blows blue smoke out the exaust occassionally, usually on startup and/or wen revved up in park/neutral
you might get away with replacing the valve guid seals, done in frame, fast fix on the cheap side.
Someone will have to chime in on the how to cause i cant type that much, sorry
Compression test measures the compression that each cylinder can generate. You can find a compression tester for $30 or so at parts stores, Sears, etc.
Leak down test is a variant of the compression test. It basically tests how air-tight the combustion chamber is with the valves closed. Testers usually run in the $60 to $125 range.
Get a compression tester and see if any of the cylinders are out of spec. Your problem sounds more like valve guide seals, as the two guys above said.
would valve-guide seals be something that will go bad if the engine sat up for like 2-3 years?
Yes......However, they are also a part of normal wear and tear.
Sitting unlubricated for 2-3 years, and being put back into service can accelerate the problem.
Sounds like valve guide seals..........a lot cheaper than a overhaul.
2x.... guides/seals are letting oil drip into the combustion chamber after running and on gassing it, sucking in oil past the guides.
The umbrella seals (rubber seals that go over the valve guide bosses) can be replaced with the engine in-situ. Umbrella seals typically crumble over time due to age and heat and pulling the valve covers to have a peek will usually reveal that condition. However, it could still be the valve guides which requires removing the heads.
Call up the parts stores and ask what they charge for rebuilt heads. Then call up machine shops and ask them what it will cost to have your heads rebuilt with a valve job, new guides, and seals. They might want to replace certain valves if their out of spec (bent/worn). Btw, I'm assuming you're doing the remove & replace procedure.
soo you think i should just get my heads rebuilt? and what do you mean by remove and replace?
By the symptoms, that is what it seems to need.
"Remove and Replace" or "R & R".... you disassemble the engine enough to remove the heads, deliver the heads to a shop, pick up the heads from the shop, and you reassemble, adjust, and fire it up. Do your research, follow a manual, and be methodical... and take many pics along the way.
About the only special tool I can think of is a 1/2-inch drive torque wrench... every tool box should have one anyway. That is one tool that is truly an investment so buy a quality torque wrench. I prefer the type that clicks upon reaching the specified torque.... I don't trust beam torque wrenches nor the newer digital/electronic versions.
Oh, add feeler gauges to your tool list but ya prolly have a set already for setting spark plug gaps.
