6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
turbo failure
Old Dec 4, 2012 | 08:21 PM
fougazi's Avatar
fougazi
turbo failure
Anyone ever have turbos spew oil and not take out exhaust sensors? I have a stock f-250 with 93k miles and just lost turbos. My warranty is almost up, just want to know what to look for.
thanks
Old Dec 4, 2012 | 09:10 PM
vloney's Avatar
vloney
thanks
Intercooler can be full of oil (possible diesel runaway) DPF can be plugged solid.
Old Dec 5, 2012 | 08:05 AM
senix's Avatar
senix
How did you determine the turbo's were bad?
Old Dec 5, 2012 | 11:19 AM
parkland's Avatar
parkland
X2
Also if you still have warranty, why bother worrying?
Take it in and let them fix it !
Old Dec 5, 2012 | 09:32 PM
fougazi's Avatar
fougazi
The turbos were making a grinding noise and then went out completely. The truck had almost no power, then went into limp mode for a 1/4 mile, mph went way down and the truck shut it self off. The dealership said they were spewing oil, they replaced both yesterday. Test drove the truck today and said it fine now. I just drove the truck and everything seemed fine untill, in the middle of accelerating the truck sputtered a couple seconds(around 50 mph). I couldn't get it to do it again. Any ideas? I'm worried about the warranty because it is up the end of this month.
Old Dec 5, 2012 | 10:45 PM
parkland's Avatar
parkland
I'd drain the water seperator, and take it back, maybe codes stored.
Old Dec 5, 2012 | 10:53 PM
fougazi's Avatar
fougazi
I have an edge cts, shows no codes right now. I'll drain it and see what it looks like.
thanks
Old Dec 6, 2012 | 05:10 AM
senix's Avatar
senix
I think what I woud do is run it real hard and see how it goes. If you can tow with it. so this sounds like bearing failures.
Old Dec 6, 2012 | 09:19 AM
wp6529's Avatar
wp6529
Honestly, I'd consider trading it in before the warranty is gone.
Old Dec 6, 2012 | 08:58 PM
fougazi's Avatar
fougazi
Trust me i've looked into it (before mine was even out of the shop). Just cant get the numbers to work for the 6.7L.
Old Dec 7, 2012 | 07:31 PM
fougazi's Avatar
fougazi
I've put over 300 highway mile on the truck so far, it seems to be running good. I am worried because it hasn't had a regen yet, before it would come on every 100 miles or so and stay on for about 20 miles. What do you guys think?
Old Dec 7, 2012 | 07:44 PM
senix's Avatar
senix
I would not worry about that aspect of it. Perhaps the turbo's were speaking long before that by overboosting and causing more frequent regens.
Old Dec 7, 2012 | 07:51 PM
slowmans's Avatar
slowmans
if ford put new turbos on they will be warrantied for 12 months or 12k miles I believe
Fixo
Jun 14, 2017 12:31 PM
SHAWN056.0
Jul 17, 2010 06:58 PM
1 Ton Tommy
Feb 26, 2010 08:36 PM
tttario
Jun 10, 2007 08:47 PM
