Compressor Housing
In order to understand how an 'anti-surge' compressor housing works (which is technically a 'ported shroud'), you need understand what surge is, in the first place.
Surge: The 'Surge Line' is the leftmost boundary of a compressor map. This is where flow instability occurs - This is where the compressor wheel is spinning at a high enough speed to force more air than the engine can injest. On initial thought, one might think this would just give you more pressure in the intake - and this is true, as long as you are on the compressor map. Basically, the surge line is the MINIMUM airflow needed to keep the pressure from backing up, and causing reverse flow pressure waves - these are INCREDIBLY damaging to the turbocharger!
Follow that thought a little further - when are you constantly seeing high flow of air, but little entering the intake? That's right, when you get off the throttle from boosting. This surging is what a BOV protects the turbo from. You also see this, if you have attempt to spin a compressor wheel such that it is forcing more air into the intake than the engine can take - or attempting to get more boost per rpm of the compressor wheel, than it is designed for.
That said, the ported shroud allows the surge line to be moved further left - this is because the compressor housing allows some of the air that starts to get backed up in the intake, to flow back out the housing.
This was stolen from another post pf
The way I understand it, you may loose spool time, but you will not loose "effective" boost.
What you need to do is figure out how you are using your truck, then go from there.
Good Luck, because personally, that is the hardest question I have tried to answer. Everything just doesnt seem to apply while modding.
The "Wicked Wheel" is a downgrade from the SD wheel. It is a stock OBS wheel and move slightly less air which is why it cures a lot of the surge issue. I have a van charger with the ported housing. It spools awesome and as well as my stock OBS charger with the same size exhaust housing. I would put a 38r on before I would mess with a van charger and ported housing though. This setup was on the truck when I bought it.
Robert6401
07-14-2013 09:45 AM
rusty70f100
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
07-08-2004 01:08 AM
