IAH delete ?
Dec 3, 2012 | 08:22 PM
IAH delete ?
I plan to plumb a boost gauge from the hole.
Question is, does anyone here remove the relay? Is it just safer to leave those wires landed in a safe place?
Will that relay make a spare for the glow plug relay?
I should have done more search but I'm gettin old and I aint as ept as I once was.
Dec 3, 2012 | 08:31 PM
It makes a great spare glow plug relay. I swapped my wife's a couple of years ago when her GPR went out and she's been using it ever since. That's a good enough reason to leave it in place.
Dec 3, 2012 | 08:40 PM
I removed the heater and the wire going from the relay to the heater.
Now if the GPR goes out all I need to do is swap them
Dec 3, 2012 | 08:55 PM
I don't have GPR's - thanks CA emissions.
My relays went the way of the Dodo bird. I put a couple layers of shrink tubing over the ends of the 'hot' wires and removed the ground wire.
Dec 3, 2012 | 09:06 PM
Thanx
I knew I could count on the FTE crew
blue66tang95f150
Sep 19, 2017 03:28 PM
kx450frider617
17
Feb 8, 2014 05:35 PM
2danglong
Sep 8, 2008 08:24 AM
Stroker4Life
16
Dec 7, 2006 07:32 AM
nutmg1
Aug 30, 2006 07:06 PM
