why cant i replace glow plug relay with a solenoid ??
i have continuous duty solenoids laying around. do i really need a new $ 110.00 dollar gpr also i know stancor makes a great replacement for my faulty gpr but i dont want to have to go to town and traipse all over to find one..
any comment , ideas...
If you have some relays that are rated for the task and you know how to wire them, there is no reason you cannot do that.
I'm currently using my intake air heater relay as a glow plug relay. I had deleted the IAH before and it was just sitting there next to the glow plug relay. When the GPR failed one morning, it was a simple matter of moving the wiring. Been that way for about 3 years now and no plans to change it until it fails.
Thank you very much Marv.
If you all think about the design of the GPR vs the AIH relay, the AIH relay being nearly twice as tall as the GPR....
Now look at the element that it has to drive. Basically an oven coil mounted in the intake stream.
When it comes on it stays on for a long time. That requires a pretty hefty continuous duty relay - a perfect candidate for use as a glow plug relay.
