Rear end
Old Dec 3, 2012 | 04:05 PM
wheeler1949's Avatar
wheeler1949
Rear end
I have a 2008 ford f150 4.7 liter 4x2 & the problem i am having is when coming to a stop when i accelerate there is a slight shemy in back end or could be described as a vibration for just a few seconds and then you don't feel it anymore untill you come to a stop & restart.Once you have pulled off it will not do it anymore out on road.I checked fluid & it is not low in back end.Transmission shifts good so any advice as to what could cause this.Any help would be appreciated.
Old Dec 3, 2012 | 05:15 PM
danorules's Avatar
danorules
It may be the rear end needs friction modifier, if you have limited slip. Could be a sticking brake caliper or bad bearing. Also a possibility is the torque converter. I would figure out if you have the ls and start there. If not then jack up the truck and check thebbrakes
Old Dec 3, 2012 | 05:50 PM
wheeler1949
Rear end
How would i know by looking at calipers if one is trying to stick. Thanks for your help
biscuit141
Sep 3, 2012 08:14 AM
fxsmit9
1997 - 2003 F150
16
Mar 12, 2012 11:34 PM
fastball
Nov 12, 2008 07:02 AM
rebuild03
Sep 21, 2004 01:55 PM
J. E. Ray
2004 - 2008 F150
Apr 16, 2004 05:26 PM
