Duraspark
Old May 23, 2003 | 04:15 PM
cseay1's Avatar
cseay1
Duraspark
I have installed a Duraspark ignition on my '68 F100. The RED wire needs battery voltage in RUN and START modes to power the module, and the WHITE wire needs battery voltage in the START mode to retard the timing for starting. The WHITE wire I hooked up to the small red wire from the ignition switch that goes to the starter solenoid. OK. But what is a good source for battery voltage in RUN and START to feed the RED wire? The only socket that seems to have that is the ignition coil socket, which has the coil resistance wire (first it is less than battery voltage, and second you can't splice into it) and then a puny light blue 18 gauge wire which goes to ????? I have the RED wire hooked to this little wire and so far it does ok -- but I have only run it for about 2 hours. Anyone have any experience with this? Is there a better option -- perhaps using a relay? I have no idea how much juice that red wire on the module draws.
Chris Seay
Bealeton, VA
68 F100
raven3
Apr 10, 2014 10:15 AM
cseay1
May 23, 2003 08:05 AM
cseay1
Dec 5, 2002 08:01 AM
cseay1
Nov 8, 2002 07:56 PM
cseay1
Mar 17, 2002 07:55 PM
