Final Drive gears
Old Dec 3, 2012 | 06:39 AM
Blackduck59's Avatar
Blackduck59
Final Drive gears
Looking for a set of 3:08 gears for a F350.
Any recommendations on manufacturer or any to stay away from?
Looking at Driveline or Superior Axle.
Thanks Steve
Old Dec 3, 2012 | 08:44 AM
Barkin 40s's Avatar
Barkin 40s
stay away from the cheapest on the list. usually a sign of quality. i would go with a midrange price depending on what you use the truck for and how many miles you put on it
Old Dec 3, 2012 | 10:15 AM
Yaga1973's Avatar
Yaga1973
Elder User - What???
If possible, I recommend finding a factory or a Ford Racing gear set. You can't beat factory quality when it comes to price.
Old Dec 3, 2012 | 03:20 PM
1983F1503004x4's Avatar
1983F1503004x4
I think the lowest gear sets for 1 tons and 3/4 ton rears is 3.42 or somewhere around that number. Never heard of a 3.08 set for a 3/4 or 1 ton.
Now if you had an 8.8'' or 9'' rear, you'd be able to find them easily.
Old Dec 3, 2012 | 04:27 PM
joshofalltrades's Avatar
joshofalltrades
i remember reading of a 3.08 in the sterling rearend, not in a dana 60 or 70
Old Dec 3, 2012 | 06:46 PM
mdh1701's Avatar
mdh1701
D70-Not going to happen, not enough pinion offset for a gear that numerically low in this axle.
D60-There is a version of this axle used on some 83/4 diesel 250's that ran a 3.07:1 for fuel economy, referred to as a Dana 61. Specs identical to a D60 other than greater pinion offset for the taller gear.
Sterling (10.25/10.5)-Quite a few Super Duty guys with PSD's run 3.08's aftermarket, just look you'll find them.
Hope this helps!
Old Dec 4, 2012 | 02:10 AM
Blackduck59
Thanks for the replies, Should have stated it is a Sterling 10.25 and there are listings for the 3:08, just not sure of any dodgy suppliers. Both the above firms list these ratios, leaning towards Driveline. Have not seen if Yukon do them.
Will be used for towing and highway work, Cummins 5.9 in front so need the gearing for cruising.
Cheers Steve
Old Dec 4, 2012 | 04:43 AM
CountryBumkin's Avatar
CountryBumkin
Thanks Steve
I have Richmond gears in my truck. I had the gears in my truck swapped to 4.56 by a well respected "performance" builder in my area and Richmond was what he recommended/used.They have taken a beating over the past ten years or so with no issues. My truck is about 600HP on the spray.
WELCOME TO RICHMOND GEAR
hail destroyer
Jan 12, 2017 08:58 AM
JOHN2001
35
Apr 29, 2012 12:09 AM
Dustin91ford
Jun 28, 2009 08:27 AM
stangbanger
Apr 6, 2009 02:42 PM
mstaser
Apr 21, 2006 12:29 PM
