90 Fuel Gauge
Old Aug 21, 2002 | 01:07 PM
mcn420's Avatar
mcn420
90 Fuel Gauge
Hello all. My '90 has dual tanks like most of them did then, but the fuel gauge only reads for the rear. The truck will run fine off the front tank, but the gas gauge just sits at E. I jumped the wires on the switch to the fuel gauge and the rear read 1/4 of a tank like it did before and the front fell right back to E so the problem must be before the switch. My Haynes manual is little help. Does anyone know a good way to find the problem, possible causes, or what the ohms should be? Thanks in advance.
Old Aug 22, 2002 | 12:14 AM
texasbob's Avatar
texasbob
90 Fuel Gauge
Look for loose or broken wires first. Make sure you have a good ground, clean the connections. It could be corrosion giving you a bad connection or it could be the sending unit, sorry I don't know the ohms.
Bob
Old Aug 22, 2002 | 02:48 PM
gamehunter's Avatar
gamehunter
90 Fuel Gauge
Mine is exactly the same way. Front tank reads dead. When I first bought the truck it would read just over E and then as the tank became empty it would read E or below. Now it reads E all the time. My best guess was a sunken float. Never have bothered to check it out since I just run the front tank till empty and then I have the back tank to tell me how much gas I really have left.
Old Aug 24, 2002 | 05:57 AM
kmichaelb's Avatar
kmichaelb
90 Fuel Gauge
A good way to check to see if it is the float or the gauge is diconnect the wire at the fuel tank. And ground it the frame with the key on. If the gauge is good it will read full. I hope this helps a little.
Old Aug 27, 2002 | 11:27 PM
redf250's Avatar
redf250
90 Fuel Gauge
This is an interesting topic to me as well. My 94 F250 has the same problem with the front tank (no gauge reading) while the rear tank is accurate. I also noticed that during the past year or two, when it was warm out, it would read again, when cold, it would not. I theorized that the wires were heating up and making a connection in warm weather. When cold, they shrunk just enough to NOT make a connection. The truck has almost 130,000 miles on it and the past 4 years I have always switched front to back to front every fillup.
I managed to mess with (technical term) the connectors on the frame rail near the front tank and it seemed to fix it for several days. Could have been a fluke (or warm out) but eventually it went back to sporadic operation. Lately, I get no reading at all, but like I said, it has been operating like this for over a year and like the previous poster, it kept pumping gas so I haven't pursued it.
However, lately, it seems I don't have the pressure in that main tank like I do in the rear. When I press the accelerator slowly, it seems like it hesitates... when I switch to the rear tank, the hesitation goes away. Any suggestions... does anyone else think this is the pump too? I figure I'll have to replace both the sending unit and pump inside the tank since I have TWO problems now.
Any suggestions on how to best do this? I know some say drop the tank, others say lift the bed. Also, where does one recommend I get the parts themselves?
Thanks
1994 F250 5.8l RegCab/LongBed 4x4 Manual Tranny
Old Aug 28, 2002 | 12:40 AM
1248bullitt's Avatar
1248bullitt
90 Fuel Gauge
90'F150
Jun 12, 2013 09:16 PM
4 flat tires
Apr 24, 2011 06:52 PM
CClark56
Oct 11, 2010 11:55 AM
55-willys
Jul 7, 2003 06:45 AM
wolf189
16
Dec 16, 2001 10:33 PM
